Question about Sony Playstation 3 (PS3) Console
My ps3 button on the back works fine, but the power button on the front isn't work. so my system won't power from sleep to play. whats wrong with it?
I did not download the 1.70 thing and it just cut off and the red keep flashing what do i do HELP ME!!!!!!!!!!!!!!!!!!!
Posted on Nov 14, 2009
Ps3 games will not play ps3 games it will play ps2 games and movies whats wrong with the system?
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Thank you
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
My ps3 isn playing ps2 games but not ps3 or dvd's what is wrong what my ps3
Welcome to Fixya
Restore File System
Rebuild Data Base
Nov 26, 2010 | Sony Playstation 3 (PS3) Console
My ps3 keep freezn whats wrong
you may want to try a hard reset. it is a last resort but should clear your issues.
If it works be kind and leave me a short testimonial for my help. Thanks
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully this will solve your freezing problems.
Problems/symptons that this appears to have resolved:
-freezing when doing anything
-no harddrive activity
-freezing when trying to use onboard keyboard or bringing up keyboard
-game/movie disc freezes system
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
Games wont load
try reseting
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
  • That's it, your video settings are reset and you should be able to choose your input and configure it from there
  • Also
    Hard Reset procedure for the PS3 (as instructed by Sony CS).
    alsoMe and some other people thought that the Reset button was on the back, on the upper center with the white marking. Thats not the reset button. The reset button is to the right. You need a machanical pencil (with lead extended) to poke it.
    Dec 31, 2009 | Sony Playstation 3 (PS3) Console
    My ps3 won't play my disk-based games
    This sounds a similar problem what I had. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu.
    I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
    In case you have the similar problem, you should try the following steps;
    The PS3 has a special Recovery Menu, which you can access in the following way;:
    1. Turn off Playstation 3.
    2. Hold the power button down; the system will turn on and turn off once again.
    3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
    4. When you hear the 2 beeps take finger off power button.
    5. You will be prompted to plug in your controller via USB and then hit the PS button
    6. The Recovery menu will pop up.
    The current Recovery Menu supports:
    • Restart System: Restarts the PLAYSTATION 3 System.
    • Restore Default Settings: Reset all system settings back to default.
    • Restore File System: Checks for corrupt/missing system files.
    • Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
    • Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
    • System Update: Update the PLAYSTATION 3 System
    Select option "Rebuild Database".
    After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
    Jun 18, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 will not play any games
    I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
    Jun 07, 2009 | Sony PlayStation® 3 (60 GB) Console
    Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Hello can you help with this error!
    When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
    Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
    Hope this helps.
    Sep 05, 2008 | Sony Playstation 3 (PS3) Console
    PS3 not playing games
    I had exactly the same problem. I managed to fix it by executing so called Rebuild Database operation.
    I followed these instructions;
    After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
    Jan 30, 2008 | Sony Playstation 3 (PS3) Console
    Ps3 wont turn back on
    if you cant get your disk out of your ps3 turn off in back of console hold down the power button with the eject button at the same time turn on the console in back while holding both buttons keep holding until disk ejects might take few times
    Oct 20, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
