Question about Angelcare Deluxe Movement Sensor & Sound Baby Monitor
My parent unit wont do anything, it just flashes with the nursery unit simble and i can not access the menu.
  • bits_and_bik Nov 14, 2009
    My parent unit wont do anything, it just flashes with the nursery unit simble and i can not access the menu. I have removed the batteries from both units to see if they would reset, but still not picking up the signal from the sender!
  • bits_and_bik Nov 15, 2009
    i could of done that in the first place
  • 10,865 Answers
Hello. Thanks for choosing Fixya! As a grandparent, I would love to fully resolve your issue right here and now. The problem I have run into is that this company, Angelcare, unlike the vast majority of companies, does not make their manuals available on line or through their company website. Therefore, the best I can do is to give you a more generic answer, which I hope will solve your problem.
If your unit runs on batteries, clean all of the battery terminals in the unit with the eraser end of a common pencil. Also use fresh, new batteries. If your unit uses an adapter, take the unit and the adapter to a Radio Shack store and ask them to test the adapter for you. Do the same things with the child unit. Hopefully, this will solve your problem and you will be all set. On the other hand, if it still does not work, you may no choice but to replace it. If that is the case, I do not recommend the Angelcare products for the very reasons stated above. Enjoy you little one. Best regards, Joe.
Posted on Nov 16, 2009
  • 301 Answers
Http://www.gracobaby.com/CustomerService/ProductInstructions/Pages/default.aspx?page=ProdInst Refer to the link I provided and contact the manufacturer Graco Baby Products. They will be able to help you.
Posted on Nov 15, 2009
  • 19,396 Answers
Hi.
Try resetting the system.
This is done removing the batteries from all the handset and from sensor unit.
Put back batteries and see if the handsets are syncing together , and detecting the sensor unit.
If not, then there may be a fault, in that case better to call the manufacturer at the support number listed on the instructions.
Regards.
See also:
Contact Angelcare about baby Monitor and products | Angelcare Monitor
Angelcare Help | Angelcare Monitor
Angelcare Baby Monitor UK Contact Us
Posted on Nov 14, 2009
2 Suggested Answers
  • 7 Answers
SOURCE: My parent unit wont do anything, it just flashes
Manuals here: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
Had same problem - here's what worked for AC401 (from manual):
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT: If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and press and hold the MENU button ,the "out of range"indicator will flash and you will hear a beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect. The Tic light flashes.This normally happens within a few seconds and you will hear a bleep to confirm it. If successful, the parents unit display will first show the channel of transmission (C1 to C8), which will be replaced by the room temperature and icons for all activated functions.
Posted on Dec 28, 2009
Hello I have a Angelcare baby monitor model ac1100 and have had it 1& half years it hasn't put a foot wrong and all of a sudden the tv monitor side of it is not working properly! It stays a blue screen and...
If you can only see two lines appearing on the screen this may indicate that the parent unit is searching for a signal from its partner and cannot locate one. Check that the nursery unit has fresh batteries and is switched on. If all ok with the nursery unit you may need to "re-pair" the two units together as per instructions. Note that the maximum distance between the Parent Unit and the Nursery Unit is approx. 100 metres indoors. In reality the Signal Strength Indicator on the parent unit should show the strength of signal between the Parent Unit and Nursery Unit. The Out of Range Indicator should alarm when the two units have lost connection and the Out of Range Icon will be visible in the Parent Unit screen. However these units sometimes require a "re-pairing" exercise to get them to communicate with each other again. Ensure both units have fresh batteries.
HOW TO RECONNECT THE PARENT AND NURSERY UNIT
In the unlikely event that the connection between the Nursery Unit and the Parents Unit is completely lost, please follow these steps to restore the connection:
1. Turn both the Parents Unit and the Nursery Unit OFF
2. Turn the Nursery Unit ON
3. Press and release the left wing 4 times. The nightlight will fl ash.
4. Turn the Parent Unit ON. A blue screen will appear with the NO SIGNAL icon in the Parent Unit Settings Bar
5. While pressing the TALK BACK button on the right hand side of the Parent Unit, press and release the POWER button on the left hand side of the Parent Unit
6. If successful, the video capture will appear on the Parent Unit's screen again. The connection was successfully restored
Jan 18, 2014 | Baby Gear
The 2 units are not pairing, the parent unit just continues to flash, despite running through the re-pair process
there is a very important step missing from the previous instructions.
turn both the nursery and parent units off.
turn on the parent unit.
hold menu for 5 secs until it beeps.
turn on the nursery unit.
press the 'clear' button at the very top of the nursery unit that is part of the halo where it meets the white plastic of the unit.
the parent unit waits for the signal then pairs.
every other guide i've found misses out this critical part of the process for some reason and i was just about to give up until i saw a guide on the angelcare facebook page linking to youtube showing 'extra features' of the angelcare monitor.
Sep 05, 2011 | Angelcare Ac401 Single Baby Movement Sound...
I request information about angel care AC401 We have build this product but we are not able to work it. When we turn on the unit parent the digital screen shown "--" and the nursery unit icon...
press and hold the little round blue light at the top for about 5 second until it beeps.
Nov 08, 2010 | Angelcare Baby Movement and Sound Monitor...
Angelcare monitor Model #AC420-P no transmittion between base and monitor. no battery problems in either
Had exactly the same problem but this worked. Never even realised there was a button on the top of the unit!!! It looks like a little LED at the base of the hoop. Happy monitoring.
Note : The connecting process should be done within 30 seconds. If longer, the operation will be
ignored and you will have to start over.
• PAGING: If you want to locate the parents unit, press the top button of the nursery unit.
Aug 10, 2010 | Toys
Both units are switched on but the parents' unit doesn't want to connect with the nursery unit. I clearly see the nursery unit's green light that flashed to detect movement and don't understand why my...
I have the same problem. I'm guessing mine is broken and will need to be replaced. However i did read a possible solution on a site with slightly different instructions to the ones in the box that describes how to pair the two devices together.
if the nursery unit just waits 20 seconds then beep beep beeps and turns off i guess yours is broken too. I think its probably the nursery unit has stopped transmitting.
they will replace or repair a unit that less than 12 months from date of purchase with a supporting receipt.
the help line is 0845 009 1789 mon-fri 11-3pm
May 20, 2010 | Angelcare Baby Movement and Sound Monitor...
Angle care wont connect to the base
Manuals: http://www.angelcare-monitor.com/Canada/en/help
Dec 20, 2009 | Angelcare 2009 Movement Sensor Baby...
I droped the monitor last night and I only get to dashes appearing on the screen and it wont pick up any sound!
Nov 26, 2009 | Angelcare Deluxe Movement Sensor & Sound...
Oct 16, 2009 | Angelcare Deluxe Movement Sensor & Sound...
The parent unit does not recognize that the nursery unit is on. all the correct lights are displayed on the nursery unit for normal function, but the parent unit display indicates that the nursery unit is...
Sounds like the units need to be paired. Start with all units off. Then turn on one of the parent units. Press and hold the menu button until it beeps. Quickly turn on the nursery unit and press and hold the button on the nursery unit that has the parent unit icon below it. After a couple of seconds the units will pair. Repeat this process with the other parent unit.
Oct 10, 2009 | Bebesounds Ac401 2p Angelcare Deluxe...
My parent unit is not working. All it does is flash when it's supposed to show me the pendulum swinging, room temp etc. I have forgotten how to reset it. Help please
Oct 02, 2009 | Angelcare Deluxe Movement Sensor & Sound...
Angelcare Deluxe Movement Sensor & Sound Baby Monitor Logo
683 people viewed this question
Top Angelcare Baby Gear Experts
Pamela Leach
Pamela Leach
Are you an Angelcare Baby Gear Expert? Answer questions, earn points and help others
