My Dell Inspiron 1200 will not run on ac power supply. It drains the battery and this is when it is plugged into the power. I have it set to desktop scheme as I always use it inside the home and have it plugged in. I can not find a way to set it to always use ac power. any suggestions. I have ordered a new power adapter to see if that could be as issue. I haven't received it as yet.
    Scholar:
  • 57 Answers
I've had a similar issue and believe the problem could be one of two things. 1.) Your power supply, so you may want to disconnect and reconnect (very firmly) the powersupply to the computer, wall, and inbetween if you have two cord device. Also you may want to try a different electrical outlet. 2.) It could likely be the power connection to the motherboard, you can test this by "gently" applying constant pressure to where the power supply connects to the laptop. You can do this by slowly, but gently, pressing up, down, left and right on the connector to see if the power on your laptop goes from battery use to "On AC Power". I would suggest imanging the face of a clock and starting at 1 o'clock and moving ever so slowly around to 12 o'clock. If your AC Power does kick on then it is definately your motherboard connection and a repair or replacement for the motherboard is in order. *** NOTE press gently, if this is not the problem you don't want to break it and have this become the problem. ***
Hope this helps, Best Regards, -md
Posted on Nov 14, 2009
Dell inpiron 1200 bios A07/run set up/system or admin password! need real solution
Try this;
Flashing the BIOS From the Hard Drive
1. Ensure that the AC adapter is plugged in, the main battery is properly installed, and a network cable is attached.
2. Boot up the computer.
3. Locate the latest BIOS update file for your computer at support.dell.com.
4. Click Download Now to download the file.
5. If the Export Compliance Disclaimer window appears, click Yes, I Accept this Agreement.
The File Download window appears.
6. Click Save this program to disk and then click OK.
The Save In window appears.
7. Click the down arrow to view the Save In menu, select Desktop, and then click Save.
The file downloads to your desktop.
8. Click Close if the Download Complete window appears.
The file icon appears on your desktop and is titled the same as the downloaded BIOS update file.
9. Double-click the file icon on the desktop and follow the instructions on the screen.
Feb 13, 2014 | Dell Inspiron 1200 Notebook
Inspiron 518 power save mode on start up
whoa are you serious the battery is for the clock on low power settings. you going to need replacement on the power supply brick sounds like it had a over charge and some components are burnt resulting in lower power setting to that brick I believe they run about $39.00 for a new brick get a genuine Dell 300w Power PSU Power brick dell support to would be helpful
Feb 01, 2013 | Dell Inspiron 518 Desktop Computer
How to switch the laptop to ac power source
Connect the mains charging adapter to the laptop and it will automatically run off the mains supply as well as charging the laltop battery.
Apr 08, 2012 | Dell Inspiron 1200 Notebook
Dell inspiron 1501 cannot indentify ac adapter
try this first. drain the flea power. remove batter and ac adapter. press and hold on the power button for 10 seconds. plug back ac adapter and battery. go online to http:support.dell.com then download the latest bios update.
once you reach the dell support site select on support for home users. then drivers and downloads. enter the service tag.
when the list of drivers and updates are listed make sure you selected the correct operating system. look for the BIOS then download it via browser. (do not download the manager)
after the download run or install the update.
If all fails. try a diff ac adapter if same problem message appears then replace the motherboard. else replace ac adapter.
Mar 30, 2010 | Dell Inspiron 1501 Notebook
Problem with dell 1200 inspiron power
please remove all the components like battery , ac adapter , any external device connected to system.
press and hold power button for 10 seconds and release the power button .
try to power on the system with plugging in ac adapter directly in to system .
if system powers on then connect battery after powering off the system.
if it does not powers on then remove memory, wireless card, harddrive and optical drive by following this link. http://support.dell.com/support/edocs/systems/ins2200/en/index.htm
and try to power on the system after all the componenets are removed.
if you get power light then start fixing all the component again one by one and try to isolate the faulty device.
if there is no power after all the componenets are removed then you will have to replace the system mother board.
Mar 22, 2010 | Dell Inspiron 1200 Notebook
I have a dell inspiron 6000 laptop When i press the start button the power lights stay on for about 5 seconds , then it switches off again. I dose not seam to engage the the operating system I would like...
Check that your power supply/AC adpater is plugged in and working. It could be that you are running on the battery only and if the battery is drained, it tries to start then shuts down again.
Feb 11, 2010 | Dell Inspiron 6000 Notebook
Back light fine with power supply and goes off on battery.
I would need to know what operating system you are running because Vista has a setting for the display brightness when running on batteries. I would suspect that, that setting is turned down to conserve battery power. If this is not the case, then the battery may be too weak to put out the correct voltage requirements for the display. If you have Vista, go to the control panel > power options > In the left pane, look for the display brightness > here you can change the brightness for running on battery and for AC power.
Oct 14, 2009 | Dell Inspiron 1720 Notebook
Dell inspiron 8100 no ac power-power only with battery
You may have to run the battery/charger utility test.Look under control panel classic view.
Jul 14, 2009 | Computers & Internet
Dell Inspirion 1526 Laptop Battery is not charging
Sound like the battery. Take the battery out and there should be a power meter on it, press it, if there are three lights that flash, the battery is shot. Not all batteries will flash if they are worn out, but they are supposed to. Try a new battery, I believe this will coorect the issue.
Jun 21, 2008 | Dell Inspiron E1505 Notebook
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
