Question about Western Digital My Book World Edition 1TB Remote Access Storage System
How to manually uninstall MioNet. Easy to answer!
Could someone with MioNet please tell me exactly what the shortcut 'Start Menu, Programs, MioNet, Uninstall MioNet' points to?
It is installed on an inherited PC but is not listed in the start menu or via 'Control Panel, Add/Remove Programs'. Nor is there an obvious file in the MioNet directory.
Thanks
  • woodforwood Nov 14, 2009
    Absolutely anyone with MioNet can help with this. For any Newbies, here's how to give me the information I want:
    1. Click on the 'Start' menu, 'Programs' menu then the 'Mionet' menu.
    2. Hover the mouse pointer over the 'Uninstall MioNet' menu option
    3. Right click on this and select 'Properties'
    4. From the 'Shortcut' tab, tell me exactly what it says beside 'Target'.
    The Answer will be something like:
    "C:\Program Files\MioNet\MioProgram.exe -u"
    Many thanks.
    Thanks, Ikkenom, but this isn't what I want. Deleting isn't the same as uninstalling. It will just leave redundant registry entries and the like. I'd like the program removed properly and therefore want to know the full command line (including switches or parameters) associated with the 'Uninstall MioNet' shortcut.
Target is "C:\Program Files\MioNet\ARPMio.exe". There are no command line arguments. "Start in" directory is C:\Program Files\MioNet .
Posted on Nov 24, 2009
    Brigadier General:
  • 10,406 Answers
Just click with the SECOND (usually the RIGHT) mouse-button on the short-cut, and click on DELETE, to move the short-cut to the Windows Recycle Bin.
Then, delete all the files from the MioNet directory.
Posted on Nov 14, 2009
Remove Memory
You should always remove and uninstall programs from your PC that you are not using.
It could be beneficial to your computer's productivity and functioning to free up space.
You run the risk of running out of space on your computer if you add too many programs without uninstalling some.
It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs."
Click "Control Panel" and "Programs" and "Programs and Features."
Browse the list of programs on your computer and select one that you want to remove.
Click "Uninstall."
You may be prompted for permission from the administrator to remove the program.
Enter the administrator password or confirmation if necessary.
Check the properties of the program if it is not listed in "Programs."
You can do this by right-clicking on the program desktop icon and selecting "Properties."
Check to see if the program is compatible with the version of Windows that you are using.
Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program.
Type "Regedt32" in the box and click "OK."
Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab.
Click "Desktop" on the "Export Registry File" dialog box.
Type "Uninstall" in the "File Name" box and select "Save."
The left panel of the Registry Editor will display the programs that are currently installed.
Right-click the key in the left panel of the Registry Editor window.
Click "Delete."
Click "Yes" when you are asked to confirm deletion of the program.
Click the "File" menu and select "Exit."
This will exit the Registry Editor.
Click "Start" and "Control Panel" and click "Add or Remove Programs."
Confirm that the program is no longer listed here.
also
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Apr 22, 2013 | MusicLab BearShare
How can I uninstall eType software from my system. I can' t see it in the program list when I list the programs in install/uninstall window
Hi, We hate to see you leave but uninstalling eType is simple -
1. go into program files -> eType folder
2. Click the uninstall icon
Jul 19, 2011 | Microsoft Office Standard for PC
Get fliptoast off my computer
If you are trying to uninstall the application Fliptoast used with/for Facebook then depending on what version of windows you're using (assuming you're using windows) go to: Start, Control Panel, Programs and select uninstall a program. Then find Fliptoast in the list and uninstall it from there.
If this does not remove it you can try a program call CCleaner and you can download it from here.
Once you have this program installed open it and go to Tools and Uninstall. Find Fliptoast in the list of applications, select it then choose Run Uninstaller.
Feb 28, 2011 | Computers & Internet
When trying to uninstall a program I get the error message--intallation log not found. What does this mean and how do I fix it??
just go and manualy delete the program and then manualy delete the shortcut files on your desktop, also you can right click on you program list under the start menu to get the option of "Explore" then you can delete the start menu --> Program Files/ (program you want to delete) and shortcuts inside.
OR
You can also try reinstalling them and then uninstalling them through add remove programs or what ever built in method supported by that program.
Oct 22, 2009 | Microsoft Windows Vista Home Premium with...
My yahooo messenger doesnot open
disable your firewall and anti-virus then uninstall current version through these steps:
XP OS
To do so, kindly follow these steps:
1. Click the "Start" menu and select "Run."
2. Type "appwiz.cpl" and press "OK." (This is a shortcut to "Add or Remove Programs.")
3. Select "Yahoo! Messenger" and click "Change/Remove."
4. In the window that opens, click "Finish" to uninstall.
5. Click the "Start" menu and select "Run" again.
6. Type in "%ProgramFiles%\Yahoo!\" and press Enter.
7. Delete the "Messenger" folder.
VISTA OS
1. Click the "Start" menu and select "Run." If you do not see the Run command, then select Start > All Programs > Accessories > Run.
2. Type in "appwiz.cpl" and press Enter. This opens "Programs and Features."
3. Select "Yahoo! Messenger" and click "Uninstall."
4. Click the "Start" menu and select "Run" again.
5. Type in "%ProgramFiles%\Yahoo!\" and press Enter.
6. Delete the "Messenger" folder.
Reinstall using this link:
http://download.yahoo.com/dl/msgr10/us/ymsgr10us.exe
Sep 24, 2009 | Yahoo Messenger
Can't manage MyBookWorld 1tb we (blue rings)
The issue you are experiencing is an error on our servers. Our next version of MioNet should prevent and resolve the issue, but in the meantime you must complete the following steps to regain remote access to your My Book World (blue rings):
To create a new MioNet account, please use the following instructions:
Part A. Reset MioNet/Anywhere Access
1. Please open your web browsers and enter (without the quotes) "http://<IP address of My Book World>" or "http://mybookworld" in the address bar. The Shared Storage Manager web page will appear. The username and password it requests will be the same as your MioNet username, and the original password used for MioNet (if you changed your password on our website, it does not update the My Book World).
2. Once you have accessed the Western Digital Shared Storage Manager please select "General Setup", then choose "WD Anywhere Access settings". On the following page you will have three buttons to select: please click on the "Stop" button, wait until WD Anywhere Access status goes to "Inactive", then click the "Reset" button. Once the WD Anywhere Access Status goes to "Not Registered," (on older firmware, it will go back to Active), the My Book World has been properly reset. This will return the MioNet software on the My Book World to default settings. It will not harm your stored files.
Part B. Uninstall and Reinstall MioNet (on a computer located on the same network as My Book World)
1. Uninstall MioNet from one of your computers.
2. Insert your Western Digital installation disk or download MioNet from http://www.mionet.com/mbvista and launch the MioNet installer.
NOTE: You must use the installation disk or the link above to create your new account. Certain functionality related to the My Book World is related to the installer you use to register a new MioNet account. Failure to use the proper installer may result in the need to repeat this process.
3. Register as a new user. You will need to specify a new username and E-Mail address.
4. During the installation, MioNet should detect the now reset My Book World. Please add it to your new account.
Part C. Uninstall and Reinstall MioNet on your other computers
1. Uninstall MioNet from your other computers.
2. Install MioNet using the Western Digital installation disk or downloaded from MioNet from http://www.mionet.com/mbvista and launch the MioNet installer.
3. Register as a current user with your new account's information.
Please let us know what your new account name is and we will follow-up with additional information. We will also send you instructions on how to reset that account's password.
Aug 21, 2009 | Western Digital 500GB My Book World...
After instaling mionet i loose my ip-settings
the problem is another Filter Driver on your Network Card. MioNet installs a WinPK Filter Driver (you can't see it under the "This Connection Uses" list under Windows XP, but you can under Vista) on all of your NICs, so if there is a filter driver from other software, such as your Internet Security, you can lose Internet connection. Go to Control Panel > Network Connections, right-click on either wireless or local area connection, and go to properties. Check the "This connection uses the following items:" box for anything with the word Filter in it, select it, then click Uninstall.
MioNet is also not compatible with the following programs for this very reason:
Sygate Personal Firewall
BullGuard
Sunbelt Kerio Personal Firewall
AOL Xdrive
Dec 25, 2008 | Western Digital My Book Essential Edition...
Mionet problem
The issue you are experiencing is account bug. You must reinstall MioNet and create a new MioNet account, then attach the My Book World to the new account. You will then regain your MioNet access.
http://www.MioNet.com/mbvista -- this is the download installer for MioNet which works for blue-ring My Book Worlds. The White-Light My Book World requires different software.
Oct 08, 2008 | Western Digital My Book Essential Edition...
Could you please tell me how to uninstall norton 306 from my computer. Thank you
Option 1)))start control panel add remove programs
or
Option2))) http://www.easy-uninstall.com/
viper@fixya
Sep 22, 2008 | Computers & Internet
Western Digital My Book World Edition 1TB Remote Access Storage System Logo
4,398 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
