Question about Dryers
Starts drying for about 15 mins then stops - Dryers
  • littled209 Nov 15, 2009
    It is not a gas dryer. It is AWZ3413 vented drier.
    Thanks anyway for trying to help.
  • 126 Answers
Sounds like this is a gas dryer. Look at your burner after the dryer stops heating .Does the ignitor come on then go off without the burner firing?If so replace the 2 coils on top of gas valve wp #279834 msrp $20.00. Please rate my solution :)
Posted on Nov 14, 2009
Perm Press cycle only runs for 2 min. and jumps to 14-15 min. every time.
find your manual and read it . sounds like the cycle has a 12 to 15 minute limit .
Feb 14, 2016 | Samsung DV330AE Dryer
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
My car laguna 2000 modeel stop after 5-10 min run.and start working after 10 to 15 min wait.
Behind your harmonic balancer there is a cranshaft position sensor. When its getting hot its loosing calibration. Have that checked out.
Nov 18, 2013 | 2000 Renault Laguna Estate
My 99 banshee wont stay running for long before it die out changed coils still same thing new plugs and nothing runns for like ten min cold the dies out takes like 10 15 min to start back up thenn dies out...
are plugs wet or dry when it stops ?
if dry try running it with the fuel cap open to check for breather blockage...
if wet check ignition timing pickups...
Mar 22, 2013 | Yamaha Motorcycles
I have a DC04 and when i switch it on it works for 10-15 mins thens stops working for about 20 mins then starts working again.
Your vacuum is overheating - that's why it cuts out. You need to check everywhere possible for blockages and also make sure the washable filter is clean and dry. If the machine has been run without the washable filter in place, then the exhaust filter will be clogged and will have to be changed too.
Feb 17, 2010 | Vacuums
Starts up and heats up fine but shuts off 10 to 15 mins into drying
Check your heat discharge vent. It's probably stopped up with lent Check it completely, from the machine thru all the fittings, even the little door on the outside of your home, if you use one.
Sep 23, 2009 | Kenmore Dryers
Dryer quits after 15 mins.
Could be try olhming out the sensor. Should be a cheap fix.
Aug 07, 2009 | Kenmore 63942 Dryer
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Dryers Logo
Top Dryers Experts
