Question about Carrier Heating & Cooling
Outside AC unit working, but inside there is no air flow and fan inside will not work unless it is turned manually. Also, a little ice on outside unit.
  • morenoletici Nov 14, 2009
    thank you for your response...i will attempt. ac unit working fine until two days ago and now when we turn it on, unit outside comes on, but no air flow inside and unit won't kick in inside either. we notice ice forming on outside unit.
    Scholar:
  • 111 Answers
Depending on what type of Thermostat you have, it is usually as simple as setting a jumper for Electric heat instead of gas.
If you have a digital Thermostat then turn off the power to the Air handler and remove the thermostat. Look closely at the small jumpers and make sure your jumpers are set to elect. and not gas so the fan can run in heat mode.
If you have a standard heat cool mercury switch then same as before with the power and unscrew the thermostat, and where the yellow wire is connected if there is a factory with on the yellow, then move the factory wire to the (A) and put the yellow wire back on the (Y).
Good Luck!
Posted on Nov 14, 2009
  • Michael McQuay
    Michael McQuay Nov 16, 2009
    Yes if the Outside is running but not the inside then it will cause the outside to freeze up. In most cases there is safety's built into the systems (High and Low) Presser sensors that can shut down the unit, If the refrigeration falls below or above normal operating pressures,
    If you have fixed the Thermostat problem and still no fan then you will want to check and make sure you can spin the fan freely with your hand, (Turn off power first to unit). If it does then remove the capacitor from the unit and have a local appliance store test it for you and replace as needed.
    Keep me updated.
    Good Luck!
Have ice build up on line leading into outside unit and ice buidup on inside units on my goodman air conditioner
Turn the system off on the thermostat and set the fan to "ON", this will thaw the ice faster if it hasn't already. When the system has completely thawed, which could take hours sometimes, depending on how bad it's frozen, then turn system back to "Cool" and start these checks>
1. Make sure filters are clean!
2. Make sure there is proper airflow through vents.
3. Make sure outside condenser fan motor is running.
If you have either no or minimal airflow, check the indoor blower to make sure it's working, if it is, the evaporator coil is dirty restricting the airflow. Be sure the system is thawed because the ice will also block the airflow!
If the condenser fan motor is not running, either the capacitor or the fan motor will need to be replaced.
If your filters are clean, you have good airflow through the house, and everything comes on like it should, it will most likely be the charge of refrigerant in the system is too low and you have a leak somewhere. If you have to have it charged, be sure the system is thawed before the technician gets there, he will not be able to do anything while it's froze.
Hope this helps and good luck!
Jun 08, 2012 | Goodman Heating & Cooling
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
The inside RUUD AC unit has ice and no cold air is blown
it is likely low on coolant or as some say "freon" that or the indoor fan motor has not run properly. let it thaw completely by shutting it off and just turning on your fan switch from auto to the on positon. if you begin to feel air flow eventually you need coolant added b/c you probably have a leak from the system being old
Sep 13, 2009 | Ruud UBHC Air Conditioner
Nordyne AC unit works at first but later provided cool air. Thermostat set to 65. Power running to unit outside. Noticed ice around line outside and can send a picture. Chipped ice away. Want to know what...
If the inside fan motor is running OK you are low on refrigerant. If the inside fan motor is not running, repair the inside fan motor. Could also possibly be dirty inside coils.
Jul 20, 2009 | Heating & Cooling
Compressor is on...thermostat is set at 70, room temp is 77 and no air coming out of vents
Check to see if you are iced up. You can tell be looking at the large line going to the outside unit. If it is Iced up. Turn off ac and trun fan to on. It will thaw unit. You still could have other problems but it is a place to start. Unless you are a little familiar with Electrical and ac units their is only so much you can do. Rusty
Jun 09, 2009 | Heating & Cooling
Not blowing cool air on my Ruud, 18 years old, outside unit.
If you have ice on the Line you are iced up. If coil is iced no air can get thru. Now First. Turn of ac and turn fan to on posotion. That will thaw unit. Let it run 45 minutes. That should do it. If the fan is not running you amy have a bad fan relay. One of the reason iced up unit is dirty evap, coil inside. Try to thaw it out first. You can clean the coil with a stool brush. Does not damage the coils. Good luck
Jun 07, 2009 | Ruud UBHC Air Conditioner
My AC not working
Hi again,
The electrical supply needs checking in the outside unit.
Start at any supply fuses, and work around to the compressor.
If it is getting a supply out there, then it is a control issue. There should be a thermostat or controller that will turn the outside unit on if cooling is required. This is the defective part, as the signal to start is not getting there.
Check the outputs from the thermostat on the inside - one contact should close to turn the outside unit on.
Hope this helps. If it enables you to fix it please take a moment to rate this as fixya!
If not, I'll go on further
Thanks.
Jun 16, 2008 | Haier HPAC99ER Air Conditioner
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
1,244 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
