Question about Whirlpool AWM5125/1 Front Load Washer
Overheating Water temperature gets very hot regardless of setting
  • 264 Answers
Your stat is gone it is on the heater element if it ain't on the heater element then its on the right side on the drum i might be a little plug or it cold be a copper Corly if so its a big job if Therese a plug on your heater then its a easy job take back of the machine and have a good look a round make sure you have unplugged the machine if i was you i would go down and see your local send hand appliances shop they could do the job and its only going to cost£25 pound
Posted on Jan 08, 2008
Oven is overheating
If it has an electronic control there could be a welded contact on one of the oven relays causing the element to stay energized. A rare thing could be a shorted element that is getting a ground current bypassing the control but this usually will stay on even when the oven is off.
Feb 10, 2014 | Kenmore Ovens
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
Jan 06, 2012 | Endless Summer Pool & Spa
Saturn is overheating, tried several things.. nothing is working.
how about the coolant temp sensor, they had alot of problems with that sensor and also the plug for it,some have two of these sensors side by side, one for the gauge and the other for the fan, i would replace these first and go from ther good luck,
Apr 10, 2010 | 1997 Saturn SC
E46 Climate control blows hot air regardless of temp setting
your water controll valve located at the right side of the engine near the extreme rear end of the inlet manifold may not be working properly hence the hot air .
May 10, 2009 | 2000 BMW 3 Series
97 saturn sl2 temp light flashing and low coolant light flashing what could be the problem ? coolant is full and the heat works.
If the temp gauge is reading normal, the lights are flashing, and the coolant level is full, the level sensor in the coolant bottle is the problem. I'm a service consultant for a Saturn dealer and I've run across this many times.
Apr 17, 2009 | 1997 Saturn SL
Asko 12605 overheating the wash water
(even not taking in hot water when filling before the wash stage which seems good)
The washer fills with cold water then heats it up 3 degrees a min. Your problem does sound like a faulty thermostat. Especailly if the glass door does get hot even if it is on 85f.
May 29, 2008 | Asko Washing Machines
Cooks too hot/fast
Hi Wendigo,
Crock pots are not exact, they only have a "target" minimum temperature (to be sure they kill bacteria). It's possible you just have a relatively strong heating element.
Also, remember that the boiling point of liquids changes considerably with your altitude, so if you're in a mountainous region you may be seeing "boiling" at a lower temperature than you expect.
Nov 12, 2007 | Rival 3040-VG 4-Quart
Whirlpool AWM5125/1 Front Load Washer Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal De
