Question about Sony VAIO VGP-WKB1 Keyboard
We have a problem with sony keyboard VGP-WK4B4G4B the following keys type m=6m b=4b ,=3, X=function key 1
    Brigadier General:
  • 10,406 Answers
Replace the keyboard, and responsibly recycle the old one.
It will cost twice as much to try to fix it, as it would to replace it.
Posted on Nov 14, 2009
How can I connect Sony Vaio VGP-WKB11 Keyboard to my Sony Vaio VPCL231FX Desktop
To communicate with another BLUETOOTH device, you first need to set up the BLUETOOTH function.
1.Click Start, All Programs, and VAIO Smart Network.
2 Click the switch next to BLUETOOTH to toggle it to On in the
VAIO Smart Network window.
Make sure the WIRELESS indicator light turns on.
Jul 25, 2014 | Sony Genuine Vaio L Series Wireless 103...
How to unlock my sony keyboard vgp-wkb5fr
Accidentally locking your Vaio keyboard can cause typed letters and/or numbers to appear on the screen very slowly, or not at all. The locking function can occur if a user holds down the shift key for more than eight seconds. This feature can be unlocked through the computer's Microsoft Accessibility Options.
1. Click "Start," "Control Panel," "Ease of Access" and "Ease of Access Center."
2. Click "Make the keyboard easier to use." A new window will appear.
3. Remove the check-marks next to "Turn on Mouse Keys," "Turn on "Stick Keys" and "Turn on Filter Keys." This unlocks your keyboard.
4. Click "Apply" to save changes, then "OK" to exit the window.
if you think i misunderstands your problem or you have any other problem you can post again
Sep 01, 2011 | Sony VAIO VGP-WKB1 Keyboard
Please help. The 789uiopjkl;m./ keys have keypad numerals on the front bevel. when I try to type "uio" for example I get "456" and "jkl" gives me "123". To get the...
The number lock feature is enabled. You should see an indicator for the Num Lock (lit when on) that is next to the Caps Lock indicator.
You should be able to disable the lock by pressing Fn and Num Lock together on the keyboard. (On some Sony Vaio keyboards, type CTRL+ALT+NumLock or Shift+NumLock.) The number lock should be at the top of the keyboard near the F1-F12 keys. Sometimes the key is shared with the Scroll Lock function (otherwise it will be nearby). It's really easy for the Number lock to be enabled on some Sony keyboards; just some dirt between the keys can enable it when you didn't turn it on intentionally.
I hope this helps.
(I don't have the VGP-WKB1 wireless Sony keyboard and can't find a good picture of it to find the Num Lock key for this model.)
Jul 08, 2011 | Sony VAIO VGP-WKB1 Keyboard
The shift key on the keyboard worked half the time for a while and now it won't work at all
Try the following:
1. Press the shift key several times and check if it changes anything. This is to make sure the inner part of the key isn't sticking onto the connector.
2. Press other keys as well, like Ctrl and Caps Lock.
3. Is the other shift key working? If it is, it is most likely that the other one is faulty. If it's the case, you need to buy one from ebay.
Try to search on ebay and see if you can find just that single key, some sellers are selling just the key for a much cheaper price. If you can't find one that's selling single keys then am afraid you should buy yourself a keyboard replacement.
Hope this helps.,
May 06, 2011 | Sony VAIO VGP-WKB1 Keyboard
I have sony vaio EB series laptop, my problem is that when I type 1 it type 21, when 3 it type 0.3, when 1 below f1 key it type 1 and open help window. there are other similar keys behaving same way. I got...
Hello
If the new keyboard is behaving same, then try to plug in an external keyboard to see if that works okay. You can use any USB keyboard. If this keyboard works, you have a hardware problem and need repair from Sony Support.
Hope this helps, Good Luck
Dec 31, 2010 | Sony VAIO VGP-WKB1 Keyboard
Why are keys zero, j, k, l, m, typing as /, 1, 2, 3, ?
To save "space" on a notebook keyboard, some keys can either be "alphabetic", or be the equivalent to the "keypad" on the right-side of a full-sized desktop keyboard.
Look for a NUM LOCK key on your keyboard.
Press it to "toggle" between "normal" and "num-lock" modes.
Aug 09, 2010 | Sony VAIO VGP-WKB1 Keyboard
My wifi is
Use the "Fn" key in combination with one of the F Function keys(example - F1 F2-F3 etc.) above the set of numeric keys. It will be a dual symbol key, meaning it will have wireless icon printed on it or the word "WiFi" in addition to the F number. It is usually one of the first 3 or 4 F keys. Remember, the "Fn" key must be pushed at the same time. It is a key combination like using <shift> and a regular alpha key to put a letter in CAPS.
Hope this helps Fixa! I am online if you need further help.
Apr 08, 2010 | Sony VAIO VGP-WKB1 Keyboard
In my sony vaio laptop jklou are now typing numbers instead of letters
u r keyboard is likely to b defective or ur ram..
lightly strike/tap the keypad using ur hand..
if u r a professional, open the keyboard..deep clean all the carbon contacts beneath the keys using Iso-Propyl alcohol..put/stick 'Carbon-Dots' (available in cheap level spare market) as n where necessary..
hope it'll work..
better to seek professional supervision esp of ur system admin/vendor....
Nov 19, 2009 | Sony VAIO VGP-WKB1 Keyboard
Sony VAIO VGP-WKB1 Keyboard Logo
267 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
