Question about Acer Aspire 5100 Notebook
No wireless device
When i try to turn on the wi fi on acer 5100 it says no wireless device...it worked yesterday
  • jdkearns Jan 09, 2008
    i tried uninstalling the drivers and it would not uninstall them, said it could not because this device is not plugged in
  • 233 Answers
Shut down, unplug and remove battery.
plug back in and check it, if it still does not work
re-install wi-fi drivers .
hope this helps
thanks for you rating
Posted on Jan 08, 2008
Can't get wi-fi connection
There are a number of reasons why you may not get a wi-fi connection:
  1. No connection available
  2. Poor signal strength
  3. Wi-fi on device not turned on
  4. Faulty wi-fi driver in device
  5. Using wrong wi-fi security password
  6. Router has your MAC address blocked
  7. Faulty wi-fi module in device
If you can give specifics on what you have tried and what the results are we may be able to narrow down the possibilities.
Oct 25, 2015 | Computers & Internet
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Internet connection problems
A bit vague problem description, but try this. I am assuming you are using wi-fi.
If you have a network icon in your system tray (looks like the bars on your phone), left click on the icon and see if wi-fi is turned on. If no, turn it on. If yes, select your network, click connect, enter any passcodes, and see if you are in business. If wi-fi is on and your network is not shown, your router is not broadcasting (not a PC problem).
If no icon, open your device manager (move cursor to the right of screen, wait for menu, select settings, select control panel, select device manager). Under the Network Adapters entry, look for your wireless device, right click, and select uninstall. Make sure the "remove software" box IS NOT CHECKED... Reboot your machine. Sometimes if a device gets hosed, removing it and rebooting to let Windows reinstall it fixes the issue. If you do not have a wi-fi entry under Network, then you either do not have a wi-fi device, or the one installed is not working.
Good luck.
Aug 03, 2014 | Acer Computers & Internet
Problem with wireless and wifi connection Acer Aspire model v5-431 note book
Is the adapter turned on? That means the software, hardware, and device switch must all be in the ON position. Otherwise, it won't work. Try resetting your Wi-Fi Adapter in Device Manager.
Dec 14, 2013 | Acer Aspire 5100 Notebook
Lost wi fi connection to our wireless network, tablet displays "turning off" under the wi fi settings.
I suggest to reinstall the wireless card driver first ..just in case, this will solve any driver issues and will make it functional in case the driver or the setting are corrupted..
To download the driver in case you do not have it on disk or saved somewhere ..just go to acer.com ...select downloads ...drivers and select the model and operation system you use..
download the wifi driver ..run it again ..and after that restart ..and try to make the connection again ...Check the wireless card in device manager to see if it shows in order ...and did not appear in yellow which indicates driver related issues..
also be sure you have network signal ..and the router is functional ..in case other computer is working with this network ..check to see if the connection actually works ..
To redo the connection ..just open the settings for wireless...and click scan for networks ...In the list of available connections ..select yours..and click connect ..insert password if needed.
Good luck !
Nov 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
I can not browse using wireless.what can i do .i have instailled the drivers and yet is not working. my wifi is not coming up. if i use lan i will browse. the product is acer4315. pls help
First check your wi fi network adpater driver installed and working fine also check it is enabled.
Turn on wi fi switch on your laptop.
Check that you get signal from router very good strength.
you can access your router with defaults link.
http://192.168.1.1
or http://192.168.0.1
connect your router to computer with ethenret cable then access above link
then check in router configuration that wireless is enabled .
If it ask for user enter "admin" and password as "admin" or blank or "password"
Aug 25, 2009 | Acer Aspire 5100 Notebook
My wireless won't work
check on your laptop there is 1 wi fi switch. turn it on.
Also check in device manager that your wi fi drivers are installed correctly.
then go to my netwrok places and check you find wi fi network signal.
Jul 17, 2009 | Acer Aspire 5050-3242 Notebook
How to turn on wireless on Acer Aspire 4520 laptop
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Sep 04, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
