Question about Panasonic DMR-ES46VS DVD Recorder/VCR
Error code F03 or F04
Error code F03 shows all the time whether turned off or on. machine did not work at all, now works part time.
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: DMR-ES40V Error Code F03
If I may add to JoshOHoward's posting and with his indulgence.
The F03 (Fault 03) error indicates possible problem with your DVD's mechanism, specifically the either the spindle or the transverse servo drive. This is the motor and drive mechanism responsible for moving the carriage that contains the optical reader/laser eye forward and backwards.
What perhaps you can try:
1. do a soft reset. With no disc, press and hold the power button for more than 10 seconds. Alternately, you can unplug the unit for an hour or so.
2. Do a force initialize. With no disc inside, eject the tray, close the tray simultaneously pushing on the back skip, pause and play buttons
3. Do a full hard reset. With the unit powered off, press and hold the Stop and Channel Up buttons while powering on the main unit at the same time for about 5 seconds.
If the above does not prove to be corrective of your concern, pls post back since further diagnosis/repairs require opening the unit.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 13, 2008
My brother NX-600 keeps displaying the code F04, if I switch machine off then on again it will allow me to sew, but then stops showing the F04 message agai.
You need to find out what that particular error code means and address that particular issue. It could be something very simple but frustrating, just the same..
Search for:
Make Model error code F04
Oct 19, 2017 | Brother Sewing Machines
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
Washer stops working and displays F6
hotpoint?
"EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Aug 24, 2015 | Washing Machines
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
I have a Panasonic NV-VP60GL, it has repeatedly come up with error code f04. From what I've been advised this is to do with the loading motor. I replaced said motor and still get problem. Help please?
F04 actually just means the mechanism locks during unload. The load motor can indeed cause this, but it can be working fine, but the timing might be out. This could be something to do with the mechanical parts of the mechanism. You should examine it for broken or worn plastic parts.
Mar 19, 2015 | Panasonic Televison & Video
I have got hotpoint -ultima super silent wf 865 is getting sign f-12 pl let me know the solution.
These are the error codes : I hope it helps!
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure switch stuck on empty
Nov 11, 2014 | Washing Machines
Vcr nv-sd300 error f03
Try F04 and repeat ten times
Apr 19, 2013 | Panasonic Televison & Video
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic DMR-ES46VS DVD Recorder/VCR Logo
396 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
