Question about Kenmore Washing Machines
How do i remove the tub on a kenmore series 90 washing machine?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
To remove the tub, you'll have to remove the agitator(s), cabinet, the spanner nut and drive block.
See the following illustrated guide. You don't have to pull the pump, motor or transmission.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=bce33cd8b32f440a0adb6e8170d95aea
You also don't have to buy a special spanner wrench. I've used a short (10") pipe wrench hooked around one of the tabs on the spanner nut and by tapping the handle of the wrench, the nut should come loose.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap it up.
Make sure that the tabs on the drive tube align with the slots in the drive block when putting the washer back together.
Posted on Nov 14, 2009
Testimonial: " Thanks oldguy, I will have to cut off one of my many pipewrenchs but I couldn't find a spanner locally. Good tip on the drive block."
Kenmore 90 series mod 110. 478621 leaking from above the transmission . How to check drum seal. Thanks
Remove the agitator, you need a spanner wrench to remove the nut holding the spin tub down, then it will lift out. You will need a new tub donut seal that fits into the outer washtub, check for corrosion on the support tube, if it is corroded and not smooth, it will likely leak with the new seal.
Apr 23, 2016 | Kenmore Washing Machines
How do i get the back off my kenmore hd 90 series washing machine
YOU DONT!!! THE 90 SERIES COMES OFF OR OUT DIFFRENTLY. THE WHOLE BODY IS REMOVED BY PULLING IT FORWARD AFTER REMOVING FRONT SIDE PANELS THEN UNSCREWING 2 SCREWS. CAN THEN PULL OUT WHOLE BODY FORWARD
Oct 18, 2014 | Kenmore Washing Machines
Wahing machine makes a loud banging noise
This could be due to pending failure of the flexible joint beneath the tub
Jan 22, 2013 | Kenmore Washing Machines
Kenmore Series 90 washing machine, won't start cycle
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26912691&pathTaken=partSearch
Next, see the Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I hate to say it but it sounds like a Timer problem.
I'd use the troubleshooting section of the Service Manual and the timer testing procedures to confirm the problem.
Note that there are two types of timers with different procedures to remove them.
Also see the following for how to release the console for access to the timer and other controls.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5216f244d51176ce1069bbf148b14335
May 07, 2010 | Kenmore Washing Machines
Kenmore 90 series washer. As the tub tries to
It sounds like you have a bad timer. If you change the position of the timer and it does not change what is going on the the timer has to be bad. However I am not certain what you mean by the agitator turns all the time. Is it agitating while spinning and draining?
Apr 15, 2010 | Kenmore Washing Machines
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
My kenmore 90 series washer has a ring around the tub after wash
Use He Detergent.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 01, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series
The tub sometimes gets moved to one side. Open lid and center the tub before you test run try that first.
Jan 16, 2009 | Kenmore 23822 Top Load Washer
Kenmore Series 90
I need codes on kennmore elite calypso
Jan 12, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
256 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
