Question about Epson Stylus Pro 9600 InkJet Printer
I have a Epson 9600 pigment printer,I am using aftermarket carts and the printer thinks they are dye, how can I change printer back to pigment?
It probably has to do with the chip embedded in your cartridges. This tells the printer what kind of ink you're using. Your cartridges could have the wrong chip.
Posted on Nov 18, 2009
Why does my hp c309 Photosmart Premium printer require two black ink cartridges? Can I use just one?
The Photo Black is pigment ink (last much longer than dye ink), while the Black is dye ink. Have alook here: http://www.earthboundlight.com/phototips/dye-pigment-metamerism.html for detail explanation
May 13, 2010 | HP Photosmart Premium C309A All-In-One...
Ink for Agfa Sherpa 24m
Hi, did you find a solution to this question as I have the same problem, can't find the Agfa cartridges anywhere.
James
Mar 20, 2010 | Epson Office Equipment & Supplies
Epson 9600 no ink coming out
That happens to me as well I'm using epson R230x pigment ink. At first yellow does'nt come out. and fixing the yellow by pumping it with a solution and putting everything back ALL HEADS ARE NOT PRINTING ANYMORE....
Sep 26, 2009 | Epson Stylus Pro 9600 InkJet Printer
I need to refill a TO88120 black Epson printer cartridge.
Epson cartridges cannot be refilled like normal cartridges. They use a special ink. You would be better off buying a replacement cartridge as I've never heard of a good result with anyone who has attempted to refill an Epson. Usually leads to havong to replace a printer. Sorry I don't have a better solution.
Sep 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Change cartridge printer selects for black
Simply put...you cannot. The smaller cart is the dye black, which is used for picture printing. The larger is the pigment black which is used for text printing. You could try printing text as artwork, but i'm not sure this will work, besides, dye ink will bleed on regular paper and not look so crisp.
Aug 16, 2009 | Canon PIXMA MP600 all-In-One InkJet...
3eBk will not print. Canon MP780
Replacing the printhead may work, but it could be a problem with the cleaning assembly. Take out the 3ebk and run a cleaning, if the ink goes away on the pad where the ink cart. goes, then clean assy. is OK, and you need a new printhead.
Jul 14, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Wont recognise ink cart
I know how to fix this. This part is identical in many, many Epson models and I have lots this part. I call it the "pinset" and what it does is make contact to the chip on one side, and on a small board on the other to make the contact. The thing is, that you have to very carefully remove and insert this part and I have devised an excellent method of doing this during my several years of working with Epson printers, without taking the cartridge reciever apart as an authorized Epson tech would do. In fact, this happened recently to my Photo black slot and I fixed it in 10 minutes. It happens when someone tries to put a cartridge in with no chip on it. Putting it in is fine, but the spring loaded contacts get caught in the void where the chip is supposed to be and when you pull the cartridge out, it bends the hell out of the pinset. They are not repairable. I would not mind helping both of you... but I need something too. I have a 9600 PHOTO DYE model (T545* carts) and I either need a set of cartridges or a set of chips that I can reset. Empty, used, I don't care as long as the chip is intact and can be reset. You see, I have several bags of ink from a different model that I can change out inside the cartridges, but I don't have the right chips! Can you help me? I could send you as many pinsets as you need. I can definitely help you but I would rather arrange a meeting on the phone to walk you through it (both of you) since its a bit tricky without taking the printer apart.
Contact me and I'll privately give you my phone number.
Jan 22, 2009 | Epson Stylus Pro 9600 InkJet Printer
Epson stylus pro 9600 driver
on site tech service for epson 9600?
Dec 31, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9600 InkJet Printer Logo
223 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
