Question about Sony KP-61XBR48 61" Rear Projection Television
Our Kp-61xbr48 is 12 years old. Sound but no picture.
Our Kp-61xbr48 is 12 years old. We bought it new. Now it turns on fine but after a few minutes (the amount of time is different every time) the picture fades and goes to black but there is still sound. What part do I need to replace, how much is the part and where can I get the part. Thank you very much.
  • collincounty Nov 14, 2009
    Hello and thank you for your response. However not sure about one thing. Should there be a corona or northern lights look to the back side of the picture tube normally when it is clean or just when there is too much dust. In other words if there is this northern lights effect, does that mean it is dusty or there is another problem?
    President:
  • 1,462 Answers
When the screen goes totally dark it is from a loss of high voltage.
The symptoms you describe are common in these television. The loss of high voltage can be from a leakable path around the picture tube caused by dust and dirt; it can be caused by a weak flyback transformer that gives out after a long warm up; it can be from an overheated output transistor in the horizontal output stage; and others.
The fact that is occasionally comes back on would tend to indicate the problem may be from too much dust and dirt around the picture tube; hence somewhat dependent on humidity and environmental factors.
You might be able to try cleaning inside the set to see if that will cut down on the leakage problem. Maybe the best thing to do is this: At night, in a very dark room, turn on the set and look through the cracks in the back to see if there is corona discharging from around the back side of the picture tube. It should be a glowing like the northern lights inside the set. If so, let me know and I will give you instructions on how to get inside and clean off the dirt around the high voltage parts. But don't do it without careful instructions as the high voltage can stay around for hours after the set is turned off. (35,000 volts is typical of a set your size.)
Please leave me comment, if you need further assistance
Thanks for using FixYa!
Rnj VINODKUMAR
Posted on Nov 14, 2009
  • Vinod Kumar
    Vinod Kumar Nov 14, 2009
    It you see the light normally, when it is clean...
    You can clean when the light completely goes away, ie when the voltage completely discharged
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
I have a KP-53S25 serial number 9016794 mfg. date Oct.1996. When turning on the picture will not come on for a few minutes has got taking 20 or more minutes we had just be leaving it on instead of turning...
Electrolitic capacitors are the demise of most electronics over the long term. Most last 10 years reliabley. Your tv has approximately 150 of them and is fourteen years old. I would use an esr meter to check for bad ones in the main power supply. If you need a power supply board your estimate for a in home service call is about 450$ plus tax for P&L. by the major players.
Mar 15, 2010 | Sony KP-53S25 53" Rear Projection...
KP-51HW40
sounds like the tuner may be going out on the set.
Aug 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Picture is gone! :*(
the picture tube (what makes the TV picture work) has blown out. Just call you nearest tv reapair shop and purchase a new one. (these are kind of expensive!)
(Also, if it's fifteen years old, i think it's time to get a new T.V. hint. hint.)
Jul 03, 2008 | Zenith C27A24T 27" TV
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
KP-46S4U lose picture after a few second blink of brightness
does the from led blink if so how mant times pause then blink again?
Feb 12, 2008 | Sony KP-48S65 48" Rear Projection...
Black screen, small portion of top of picture in view at bottom of screen
your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good luck.you need the repairman.
Apr 01, 2007 | Sony KP-53HS10 TV
Black screen w/small portion of top of picture showing at bottom of screen
Hello, the problem with your projection TV is in the so called bad soldering in the vertical deflection stage. Please contact a pro in order fot fix the error. If you need more assistance please advice. Arpi
Mar 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
81 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
