Question about Motorola Mobility C168 Cellular Phone
How to lock the keypad with password - Motorola Mobility C168 Cellular Phone
I lost my instructions to change the keypad password, can you please instruct me on how to change this password?
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Jan 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
My phone keypad is locked nd i had forgot the
my phone lock but in witch my data solv this problam
Mar 03, 2010 | Nokia N70 Cellular Phone
What is the default password for micromax x2i mobile
The Keypad Lock Icon is seen on top of the screen at various positions depending on the number of icons displayed. An Open Lock signifies that the phone’s keypad is unlocked and a closed lock signifies that the keypad is locked. You can unlock the keypad by pressing Unlock (by right soft key) on the phone, followed by the Send (GREEN) key. Similarly for locking the keypad, press the End (RED) key, to be followed by the Send key.
The user guide for your phone does not indicate a default pass code. Most default passcodes are either 5 or 6 zeros. Some are 12345.
See user guide:
http://www.micromaxinfo.com/downloads/guide/X2i_UM.pdf
Jan 26, 2010 | Cell Phones
Locking keypad
Do you have a device password set on the device? If so, go to Options (wrench), General Settings, and you should be able to change the lock out time up to an hour. Press the BB Menu key and select save. Enter Password to confirm.
If you do not have a password set, somehow you are pressing the Keyboard Lock icon. To unlock, press * (asterisk) key and hit Send call button.
Jan 14, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
Pin code
Keypad lock
  • To lock the keypad, press and hold the End key until the "Unlock" option appears over the left soft key.
  • To unlock the keypad, press "Unlock" then press the star (*) key.
Phone Lock
  1. From the standby screen, select Start.
  2. Scroll to and select Settings.
  3. Scroll to and select More....
  4. Scroll to and select Security.
    message?board.id=samsung&thread.id=50072
  5. Scroll to and select Device Lock.
  6. Select Prompt if device is unused for.
  7. Scroll to and select the desired duration.
  8. Scroll to and select Password type (e.g., "Simple PIN" or "Strong alphanumeric"16x16_smiley-wink.gif.
  9. Enter password, then select Done.
    NOTE: The default password is 0000.
  10. Confirm password, then select Done.
  11. To confirm, select Yes.
Aug 03, 2009 | Cell Phones
Keypad lock
But you haven't mentioned your phone's model and make.
Generally, you have to change the default password provided in the phone's manual or company service center/ customer care. Then you can produce whatever password you wish.
Be careful not to input wrong password repeatedly (3 times).
Feb 28, 2009 | Sony Ericsson W200i Cellular Phone
Lock the keypad
You can manually lock the keypad to avoid pressing keys by accident. You can still answer an incoming call and the keypad will lock again when the call is finished. The keypad remains locked until you unlock it manually.
Depending on your phone model, you can activate the automatic keylock. When the automatic keylock is activated, the keypad locks shortly after you stop pressing keys.
Please note: with some phones you can still use external keys when the keypad is locked. If you wish to lock the external keys you must lock them separately.
K800i To manually lock the keypad:
  1. From standby, press the * key.
  2. Select "Lock keys".
To activate automatic keylock:
  1. From standby, select "Menu" > Settings.
  2. In the General (tab), select Security.
  3. Select Automatic keylock > On.
To unlock the keypad:
  2. Select "Unlock".
  3. hope this helps Thanks and God bless
Dec 15, 2008 | Sony Ericsson K800i Cellular Phone
Keypad lock
To lock the keypad so that you don't accidentally call anyone, simply press AND HOLD the red "end call" button.
To release the lock, press the left menu button, then hash (#)
Sep 15, 2008 | HTC S710 Smartphone
Samsumg C300
ok... your keypad flex might get loose or dirty keypad contacts inside or check your volume if it get stuck... or
if you can open your phone, checks its connection or keypads contacts get dirty...
hope that solves your prob...
Oct 29, 2007 | Samsung SPH-i500 Handheld
Motorola Mobility C168 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
