LG 37LC2D UD screen would not power up but display black screen, This happened after a normal power down
  • daveimme Nov 14, 2009
    When I turn the TV on...the green power light blinks more times than normal (15 times) and you see a dim flash then nothing but the green power light is on. No sound and none of the buttons work. and it will remain that way for as long as it is plugged in. This all started about a week ago. I just turned it on again to see how many blinks and counted 15.....5 minutes later the tv comes on.
    I told EVERYONE not to turn it off.
    I have a Monster power surge protector
    What's my problem?
    Thank you
    President:
  • 1,462 Answers
It seems most likely that the problem is either the backlight itself or the power supply board .
If you get sound and there is no picture then it could be issue with the back light inverter
However, if there's no "glow" around the edges when the picture is black,then i am sure that it is issue with the backlight, changing the backlight should solve your issue.
If there is an indication of the backlight working ("glow") then the problem could be anywhere in the video circuitry that drives the panel
If you dont get even sound and the unit is completely dead after switching on, here is the solution
A blown internal fuse would cause things to appear completely dead. It is not intended to be user serviced. If you do find a blown fuse, never replace it with a larger size. Using an oversized fuse may cause additional damage.
If the same size blows again there is some sort of fault, typically something like a shorted diode, electrolytic capacitor, or switching transistor.
There could be more than one fuse. Sometimes there is one on the AC power coming in, and one or more on various outputs from the main power supply. The AC line fuse may fail simply from a nasty surge coming down the power line. Other fuses usually blow from internal faults.
If your TV is completely dead you have to check the fuse, or i f you get any color indiaction on your LED, like colir changing from green to red etc, please leave it as comment, we may solve your issue
Please leave me comment, if you need further assitance
Thanks for using FixYa!
Rnj VINODKUMAR
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Posted on Nov 14, 2009
  • Vinod Kumar
    Vinod Kumar Nov 14, 2009
    I had the same issue with 2 of these sets. It ended up being 2 capacitors were bad on the power supply. They are located towards the bottom of the board, you can visually see they were buldging and leaking slightly. I replaced them with 2 capcitor of same values and the tv works as it did before....
    Please try this and leave me comment
Manual 4 LG TV model # 37LC2D-UD
Great site... including trouble shooting
http://www.lg.com/us/support-product/lg-37LC2D
(just a model that does not compute in USA)
Silly me... I was searching USA...
GO HERE:
http://www.lg.com/au/support-product/lg-37LC2D
Product Support
Apr 07, 2016 | LG Televison & Video
Bad power supply for LG "37" flat screen
Replace the power supply board as card basis. It will be best, rather than making "Surgery' to it, and to waste time and money. It can be bought from the authorized service center for LG. After replacement, certain adjustments should be done. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 17, 2013 | LG 37LC2D Television
My LG 37LC2D picture suddenly goes black and then if I bang on the corner of the set sometimes the picture will return. What is wrong with my TV?
could be the power supply card(s) is unseated..open it up if you dare and re-seat and/or maybe remove and clean the card edge connector contacts with an eraser
May 27, 2012 | LG 37LC2D Television
My LG model # 37LC2D won't turn on. The green power light will blink on standby then stay green. The screen will be black. Occasionally the picture will work fine and other times it is either black or...
Hello there,
I believe the Audio/Video Inputs/Outputs could be going out .
If you are using the HDMI try the Component cables and connections or AV cables with the S-video
if you swap the cables around and the problem is still there let me know and we try a few more steps thank you and don't forget to Rate
Jan 26, 2011 | LG 37LC2D Television
Lg 37lc2d
Is it cracked? = needs new screen
If not, you could get luck reseating the cables internally (unplug and replug).. some are fragile but sometimes reseating cables will fix these issues..
Nov 28, 2008 | LG 37LC2D Television
Televison & Video Logo
206 people viewed this question
Top Televison & Video Experts
