Question about Logitech Z-560 Computer Speakers
Left rear channel just stopped working on my Logitech Z560. Swapped cables and speakers with no problem. It's just that channel that does not work. Any suggestions?
  • randy walters Nov 15, 2009
    thanks for the suggestion. Problem not with "fade" or pan controls on module, if that's what you mean. I checked this. Any other ideas? (I've heard that the control mudule is often a problem -- the weak link in this otherwise excellent sound system.)
    Logitech doesn't sell parts though for discontinued items.
    Brigadier General:
  • 10,406 Answers
Check that you have not "panned" the sound-output to a setting of "0% left-rear, 100% right-rear".
Posted on Nov 14, 2009
Rear left channel makes my speaker pop cuts in and ou at certain settings
Swap left and right speakers. Does it stay with the speakers if so you have a blown or damaged speaker. If not then swap input cables only. If it stayed with the speaker you now know the amp has a bad channel and needs repair. If it swapped again you either have a bad cable or issue with your source unit.
Jul 26, 2016 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
RIght speaker not working in speaker system. Switching the left with right speaker make the right speaker work (not speaker) Plugging the 2 RCA into a different input changes nothing. 2 rear speakers...
Let's name the product and use FM for troubleshooting. Are you saying you have the Right Front and both rear amp channels/speakers not working? What DOES work?
Jan 17, 2011 | JVC Audio Players & Recorders
I have the logitech z560, sub works but none of the satellite speakers work
Hi, I suggest you to contact the Logitech support for a replacement this is an hardware failure and it's covered by warranty terms.
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Feb 01, 2010 | Logitech Z-560 Computer Speakers
I have an mp3 player that i want to hook up to my logitech x-540 speakers but when i do it only plays on the front, or rear speakers depending on which cord i plug it into, is there a way where i can use...
An MP3 player is a stereo device, meaning that it works on two channels - left and right. Therefore a 5.1 speaker system will only play on 2 speakers.
However, if you want to use rear speakers as well, just for the fun of it (you won't get any surround effects, both left speakers will play the left channel, and both right speakers the right channel) you can purchase a "headphone Y-adaptor", that normally allows two people to use two pairs of headphones on the same portable music device.
It has one headphone plug and two headphone sockets in parallel. Plug it into the player, and to the sockets plug the front and rear speaker cables :)
Please come back with a testimonial if helped :)
Dec 22, 2009 | Logitech X-540 Computer Speakers
Left front channel has stopped working
if you are sure you swapped speakers and its still the same, get a refund the unit is bad.
Charles
Dec 16, 2008 | Onkyo TX-SR606 Receiver
Logitech X-530 Speakers System
There are several reasons why there is no sound coming from the rear speakers.
  • Improper connection of the signal cable is a possible reason why there is no sound coming from the rear speakers.
7949.jpg Green connector is for the front left and right channel. Black connector is for the rear left and right channel. Orange connector is for the LFE (Low Frequency Effects) subwoofer and the center channel.
The connectors for the Logitech products are color coded as explained. The connectors on the sound card may not be color coded or a different color coding maybe used depending on the manufacturer of the sound card. Check the manual for the sound card to make sure the correct connector is connected from the Logitech speaker to the sound card.
  • After verifying that the connections are made correctly, the sound card needs to be checked to make sure it is setup correctly. There are many sound card manufacturers so we cannot possibly cover every make and model. We recommend contacting the manufacturer of the sound card to make sure the sound card is setup correctly for use with analog 5.1 speaker systems.
  • When a software DVD player is being used to watch a DVD, the audio output needs to be set to surround sound mode. Please refer to the user manual for the software DVD player to check the settings.
Many DVDs have more than 1 sound format available. Just as the sound card and the software DVD player, the DVD itself has to be set to the correct sound format.
  • Finally you can test to see if the speakers are working correctly by plugging the front channel cable coming from the sound card to the rear channel connector on the subwoofer. If sound comes out of the rear speakers, then there is no problem with the speakers. The problem could be with the software DVD player, or the audio setting on the DVD.
THIS article can be used to test if your speakers are indeed working.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 04, 2008 | Logitech X-530 Computer Speakers
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Channel not working
If the Logitech Pulse 475 is the same as the Labtech Pulse 475 then the left channel amplifier probably blew. The Labtec uses a 5 pin TDA2030A, which costs around $3. You will need to know how to solder to repair this. The back of the case comes off by removing the 8 screws around the back of the case and lifting it out by the power cord. Then, simply desolder the left channel amplifier marked IC201 (it's on the leftmost side of the board, next to the volume potentiometer) and solder the new amplifier in it's place.
Jun 19, 2006 | Logitech Z-680 Computer Speakers
Logitech Z-560 Computer Speakers Logo
392 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
