Question about Ovens
I need to replace the bottom element in my oven
    President:
  • 1,653 Answers
You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
To test and replace the element:
  1. Turning off the mains power to the oven.
  2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
  3. Remove the 2 power connectors to the grill element if one is fitted.
  4. Check the element resistance reading on the main oven heating element and not the grill element.
  5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
  6. Remove the earthing wire to the main oven heating element screw terminal.
  7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
  8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
  9. Reconnect the earthing wire to the element screw post.
  10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
  11. Reconnect the power cables to the main oven heating element.
  12. Reconnect the power cables to the grill element if one is fitted.
  13. Reconnect the power and check that the element works correctly.
  14. Disconnect the mains power again and replace the rear panel(s).
  15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
Posted on Nov 14, 2009
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Replacement of bottom oven element for Whirlpool oven
its only screwed in to back wall no???if screws rusted well then drill htem out.hidden bake elemnet??hidden under oven cavity??in that case right side wall of unit comes off( a few screws down back side of panel and it removes from the side.(shut power first this element is always live!!!!!!!
Posted on Feb 24, 2008
  • 220 Answers
SOURCE: The Bottom oven element has burned out. Is is
It's replaceable,if it's an exposed element meaning you can look in the oven and see the element you can do it yourself unplug the range take out the two screws securing it pull it slowly toward you,unplug the two connectors and put in the new one,if it's a hidden bake meaning you can't see the element you would be better off having it done.
Posted on Sep 23, 2009
How do i replace bottom element in blanco oven model bso632
Hi Ron.
Unfortunately I do not have the schematics for this specific model. The fan assisted oven has a top grill element and an element in the fan housing. The fan housing is located inside the oven cavity at the back and protected by a cover held by 4 screws. Here a video showing how to replace the fan assisted element. If there is also a lower element at the bottom of the cavity, this can be reached removing the panel at the bottom of the oven. Here a video showing replacement of the bottom element.
Dec 19, 2011 | Ovens
Hello, We have a bosch hbn7052gb oven. The lower oven flashed and now the bottom oven doesn't heat up, everything else works ok the fan, the top oven etc. Can you advise what needs...
Bottom element has failed. Probably 2 screws at rear to remove & replace. Disconnect fast-ons from rear - extract element - replace. best to get electrician to do this - simple job & element should be inexensive. - Rick
Jun 11, 2011 | Bosch Ovens
The bottom element in the oven does not work. Doesn't turn on. The top element is ok. We have a Hotpoint Crystale Oven (Purchased March 1990) Model Number: KE637KW1 Vic
The bottom element has failed and will need to be replaced.
You will need to remove the element by undoing the fixing screws and the electical connectors then when you have got your replacement fit it by the same method.
Remember to turn the power off before you start.
Dec 09, 2010 | Hotpoint Ovens
Bottom element quit working. changed element still not working
if your oven has an electronic control board then it needs to be replaced.make sure all your power to the unit is good and there are no loose wires on the main terminal block.If it does not have electronic control then replace the oven control switch.
Feb 24, 2010 | Ovens
Bottom oven failed blew fuse when reset only bottom oven not working
It sounds as if your bottom oven heating element has 'blown'. You will need to replace the heating element.
Dec 26, 2009 | New World E90DOa Electric Double Oven
I need to replace my bake element on the bottom of the oven. I have removed the plate but do not know how the wires disconnect
they are just a push-on spade terminal,pull them off replace the element and carefully push-on the terminals to the element
Nov 18, 2009 | Whirlpool GSC278PJS Oven
Broken Bottom Element
Remove the element and take it with you to a appliance parts supply.
They will match it with the correct replacement.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
642 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
