Question about Sony Ericsson W700i Cellular Phone
My W700i drains my battery so fast, i thought my battery was old, so i bought a new one and still it drains the battery so fast, can you help me fix my phone?tnx
  • 332 Answers
Hello, This could be as a result of running too many applications like your bluetooth, walkman etc. Try closing all applications that you are not using.
Regards
Posted on Nov 14, 2009
I bought the Tata Tiago 1 year before and now it gives the problem of faster battery discharge than any other car such as Tata Nano.
Their might some issue in the battery of your Tiago, and there may be many reasons behind this problem that you are facing like a dead battery, old battery, or bad alternator etc. If the charging system of your Tata Tiago isn't working properly, the car battery can drain even while you're driving.
A car alternator recharges the battery and powers certain electrical systems, so if the alternator has a bad diode, the battery will drain fast. Also, if the battery is old, it might not hold a full charge and drain fast. I advise you to have your car battery checked from your local Tata Motor service center or from some skilled mechanic for proper solution.
Sep 18, 2017 | Tata Cars & Trucks
My NV5378u stopped charging, thought it was the charger wasn't,bought new battery, again does not charge, why
1)How to disassemble a Gateway NV52, NV53
http://youtu.be/ab0tt7LflHw
2)Gateway NV Laptop Repair Fix Disassembly Tutorial
http://youtu.be/f65ohS_EfdI
Dec 09, 2011 | Gateway NV5378u Notebook
Battery charge gets weak so fast
Hi. This could be caused by a few different faults. Some batteries when old, can have a good voltage reading but are unable to supply the amps to drive the machine. Connect a volt-meter to the machine and try and drive it. If the voltage drops right down, then the batteries will be at fault.
Could also be loose battery terminals, or faulty battery lead in-line connectors.
If you suspect your batteries get a serviceman to do a constant current test, and see how the batteries perform.
I had a customer that had been through 6 sets of batteries in 4 years. When he finally asked us for help, we found that his charger was faulty, and overcharging his batteries.
Get a serviceman to record your charger over a complete charging cycle with a data logger, and make sure that your charger is operating corectly.
Do you make long trips in your machine, and how often do you recharge the batteries.
Most batteries are designed with a certain number of "charge cycles". If you drain your batteries by 75%, you will only get a small number of "charge cycles". If you only drain your batteries by 25%, you will get 100's of charge cycles.
Good luck. Neil.
May 30, 2010 | Jet 3 Ultra Power Chair
Actually my mobile battery is draining very fast even i am not using my mobile just except accepting the calls on my phone Even im closing all the applications properly im fully charging my mobile it shows...
Does the phone usually gets hot before the battery runs down?
Try changing the battery, maybe the battery cell is weak.
Let me know what happens after changing the battery, so that I might direct you further.
Take care.
Nov 20, 2009 | Sony Ericsson W700i Cellular Phone
Rechargable batteries drain as soon as they are put in the camera
Your circuit board has developed a short. There is only one way to fix it, replace the main circuit board. Buy an A530 camera with a cracked LCD online from someone, to fix it.
Nov 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Problem with Nokia 3310
If the battery was draining too quickly, and a new battery does the same thing, it is very possible that the phone has a defect that is causing it to draw too much currnet. This you will not be able to service yourself. You will have to send the phone out for service.
Considering the cost of servicing a phone, it may be worth to simply get a new phone.
Jerry G.
Jul 05, 2008 | Nokia 3310 Cellular Phone
Sony Ericsson W700i Cellular Phone Logo
165 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
