Question about Kitchen Ranges
I have a Westinghouse fan oven model number 05-208108 and need to install a new bottom element in the oven, but do not know how to access the bottom element cavity
  • 10,515 Answers
If you remove the rear panel inside the oven, from there you will see a round element around the fan.Remove the element and with a multimeter see if its open circuit. if so replace element and try oven.
To remove the element on some ovens you will see 2 screws on the bracket holding it on. if there's no screws there then the oven will need to be pulled out and remove the back panel and the element will be screwed on the back.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2009
How do you replace the fan oven element
Assuming you have bought your element then in most ovens this is a straight forward procedure to remove old and replace by new. Find the make and model number of your oven and google for the manual usually a number of Phillips screws hold it in and two pronged plug provides the power. New element will give you a clue to the type of connector.Hope this helps but without knowing the model it is difficult to be more specific.
Nov 01, 2011 | Ovens
To replace element in westinghouse fan forced oven.do i need to remove oven from wall
Usually the convection element is inside of the fan housing on the back wall of the oven. If it isn't there reply with exact model# and i'll look at the parts breakdown and see where it is on your model
Gene
Jul 31, 2011 | Kitchen Ranges
KitchenAid Model KESC307 has a broken oven heating element. Can you fix this yourself? How? How much is part?
Hello Tgilreath,
I understand that you are having a problem with you KitchenAid range. The oven element is broken and needs replaced and you would like to know the cost of the element.
I can instruct you on how to change the element in your range. However, I do not know if it is the top of bottom element and the change procedure is the same on both of them. However, when looking up the element to tell you where you can purchase and the cost I came across many different KitchenAid models that contained the numbers you gave. There should be more letters and numbers on your tag for the model.
The following is steps are how you change out your element:
1. Disconnect the power to the unit
2. Remove the lower back cover on your range (the one that sits directly behind your oven)
3. Locate the two prongs on the bad element sticking thru the oven wall and remove the wires
4. In the oven remove the racks
5. In the oven remove the two screws holding the element in place
6. Remove the element by pulling in forward
7. Install new element in Reverse
You can locate the element on Sears Parts Direct at the following web-page, however you will need the full model number http://www.searspartsdirect.com/partsdirect/part-model/kesc307?pathTaken=modelSearch&prst=0&shdMod=kesc307 You may also reply to this thread and I will get you a part number and the exact page you need to order the part.
Thank you for choosing FixYa.com
Justin
Mar 27, 2011 | KitchenAid KESC307 Electric Kitchen Range
I am trying to install my oven element. I am replacing old one. Oven is Westinghouse Model POL667S
tand pull the elelment out about 3". The element should lead back to a small plate at the back of the onen. Remove the two screwsi at the back of the oven.
Pull the element out about 3" and this will expose the connecting
wires, dissconnect them and remove the element. To install the new one, Just
do the removal procedure from last to first.
Nov 30, 2010 | Ovens
I need the bottom heating element in an old westinghouse wall oven. the model # is OG25HXO
I am not certain what geographic region you are in but... Bake elements are often generic between brands. The key is to match up voltage, wattage, size, bends and terminals. Here are 2 pages of westing house elements:
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Range+%2f+Stove+%2f+Oven&Brand=Westinghouse&PartType=Element+or+Burner&Electrical=Yes
I tried searching using OG25HXO with little success even on westinghouse sites US and AU.
Thanks for choosing FixYa,
Kelly
Nov 18, 2010 | Ovens
My bottom fan oven isn't heating up, the fan is working though, for model Beko DVC6531
The element has blown, you will need to replace it (should only cost
Aug 09, 2010 | Ovens
Need to know wiring for element
i removed the wires from the fan and element and cant remember which colour wire goes where is thir a pictures for baumatie oven that i can use as a guide
Feb 20, 2009 | Ovens
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Thanks.
Dec 26, 2008 | Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
