Question about Sony Playstation 3 (PS3) Console
When I turn the system on the screen will flash on and off but it doesn't do it all the time
Its happen to me it will go away simply by itself
Posted on Nov 14, 2009
The power lights flashes three times and the TV doesn't work
Three times flash to LG TVs denotes a fault with its main board. Contact any service technician. If you're sound in electronics, check this link. http://electronicshelponline.blogspot.com/ Blinking codes to many brand TVs are given in detail. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 23, 2013 | LG 47LG50 47 in. LCD HDTV
Toshiba satellite turns on but power light blinks and screen is blank
Start as basic as you can, remove everything you can, RAM, HDD, modem (if equipped), WiFi card, optical drive, etc. It should beep when powered up, complaining about missing RAM. Install RAM and see if you can get it to POST. If so, install 1 item at a time until it stops working. Bad part found.
If it doesn't complain about the ram, it's probably a bad system board. If it does complain, but doesn't post with the RAM in, it could be still be a bad stick of RAM or a bad RAM socket on the board, try one at a time, and in each of the sockets.
Sep 15, 2012 | Toshiba Satellite Computers & Internet
Problems Installing Adobe Flash Player For Firefox
The MSCONFIG file shows programs (and other services) which are scheduled to load at system startup. But that doesn't tell you which programs and services are currently running.
If you launched the Firefox browser, and then closed it, it's possible that the application file may still be open (running), even though the browser window is no longer visible. (Like other large programs, Firefox doesn't always shut down properly.) Fortunately, it's easy to check on that, and to terminate the application if necessary, by using the Windows Task Manager.
In Windows, right-click on the taskbar (at bottom of screen), and select "Start Task Manager". Then click on the "Processes" tab, and scroll down to see if "firefox.exe" is listed. If so, highlight that entry, and click on "End Process". That will terminate all Firefox processes, so other activities (such as Adobe Flash installation) should be able to proceed.
See also this Firefox help file:
http://support.mozilla.com/en-US/kb/Firefox%20is%20already%20running%20but%20is%20not%20responding
Hope that's helpful.
Nov 29, 2011 | Adobe Systems Adobe Flash Player
1999 Lincoln Continental was in for repairs and now my turn signals and break lights dont work. Im being told it's something to do with the anti theft system because the battery was unhooked. The...
I suspect there is a problem with the turn signal/ hazard switch. turn the turn signal on left or right, if it doesn't flash, grip the hazard button and gently wiggle it around, if the signals start flashing, replace the turn signal switch. The Brake lights are wired through the turn signal switch, if the 3rd brake light works, the brake switch is OK. I don't think it has anything to do with the anti theft system (at this time)
Sep 21, 2011 | 1999 Lincoln Continental
ERROR 8002F1F9 DURING AN UPDATE THROUGHT PS3 **** (NOT INTERNET) EVERY TIME I OPEN THE CONCOLE IT TRYIES TO UPDATE AND STOPS AT 55%
From my knowledge on ERROR 8002F1F9, you need to try the system recovery menu and if that doesn't work you need to contact Playstation customer support: 800-345-7669.
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Sep 14, 2011 | Video Game Consoles & Games
Ps3 will turn on but wont come up on screen it wont turn off or eject disks
If your system:
1. Beeps three times
2. Blinks the Red LED light
3. Flashes a quick Yellow LED before turning Red
Your system might have experienced the "Yellow Light of Death". This is usually a sign that the system has overheated. Try turning off and unplugging your system from the power outlet and leaving it for a couple of hours.
If the system still doesn't turn on/boot up after a couple of hours, you should contact Sony (especially if you are still in warranty).
If your system is no longer in warranty and you know how to tinker with electronics AND given that your system is the old "Fat" version, then you could try fixing the system yourself.
Since the YLoD or "Yellow Light of Death" is a general hardware failure, given that if your problem is with some components of your system (such as the GPU's solder/thermal paste getting dry/broken) it can be fixed through a couple of procedures.
Please proceed to this Forum Thread to see the procedures:
http://community.us.playstation.com/thread/484908?start=0&tstart=0
http://playstationlifestyle.net/forums/showthread.php?t=2376
Note that this does not apply on all systems that experienced the YLoD.
Apr 22, 2011 | Sony Playstation 3 (PS3) Console
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
Mar 17, 2011 | Motorola Mobility H720 89382N Bluetooth...
Powering up
I think the battery is the problem. But does it power up when connected to the power?
Also please mention the model number.
Do you remember what hapenned the last time it worked ?
Nov 16, 2008 | Acer Computers & Internet
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
