Question about Kenmore HE5
Air in dryer not hot? - Kenmore HE5
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Nov 14, 2009
Why would my crosley dryer get really hot but the clothes don't get dry
If the dryer is getting hot (the heater element is working) but the clothes aren't drying, it suggests that there is insufficient air flow through the dryer. Remove the exhaust tube from the back of the dryer. With the tube removed and the dryer running, check for hot air (lots of it) flowing out the exhaust vent of the dryer. If there is good air flow, check the exhaust tube for lint build-up or a clog that is blocking the air from flowing through the tube. If there is no air coming out of the exhaust vent with the exhaust tube removed and the dryer running, it suggests that the problem is with the exhaust fan inside the dryer.
Jul 08, 2014 | Crosley CDE6000 Electric Dryer
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
Dryer not getting hot enough
the heat sensor or spark ignitor is at fault
Feb 28, 2010 | Whirlpool LER4634J Electric Dryer
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Dryer gets too hot
if it gets too hot with new limit you might need to take dryer to neighbors yard and blow out all lint from whole unit from the lint filter, blower, indide and exhaust hose and also check the flapper where the air goes outside
and blowing out the lint from an old dryer with an air compressor makes a BIG MESS
good luck
Jul 03, 2009 | Dryers
Dryer working but not blowing hot air
it sound like the heating element. look to see if it is broken
May 08, 2009 | Bosch Dryers
Wont blow hot air
heating element failure 30 bucks and an hour of labor
Jan 14, 2009 | Dryers
Air flow and heating problem inside dryer.
???? this doesnt make much sense, can see how you would be measuring air flow within the cabinet??? air blowing out unit strong means your gettin good air flow fom within, that is a direct relation as to the amount of (hot) air being pulled across the clothing
Jan 14, 2009 | Whirlpool LER4634J Electric Dryer
Electric dryer only has hot air, or air dry
This is one of those problems that could be a number of issues. It could be a timer contact stuck in a hot condition, it could be the operating thermostat inside the unit, or if you have a heat cycle selector switch, it may have shorted as well. Each one of these items should be tested with an ohm meter to verify which one of them is the bad part. Let me know if you need further help.
Feb 14, 2008 | Dryers
Kenmore HE5 Logo
76 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
