Question about Kodak i65
I 65 scanner sensor
The girls in one of my out of town offices tell me that there is a small black sensor beside the feed module. I would like to find an exploded view of the inner workings so I can order parts. Can you tell me where I can find something like a parts manual? Thanks, Bob
  • blawson Jan 14, 2008
    We found that the feed module (162-3362) was in excellent condition, but the lever/spring assembly had been knocked off the black paper sensor located beside the module. Fortunately they had found one of the pieces, and the other one was rattling around inside the unit. I was able to get the parts to click back into the assembly and the unit works. This black sensor is apparently a slotted optical device and the lever causes the light to be blocked (or opened) when there is a bundle of pages in the top tray to be scanned. This is a rather delicate looking device, and i would like to buy one to have in stock, because next time we might not find these tiny pieces. I did not see one on the parts page, although there is one item with no picture. If you can steer me to these, I would appreciate it. Thanks, Bob
  • 233 Answers
Go here and scroll down, you will see the feed module for $31
replace that
hope this helps
thanks for your rating
Posted on Jan 08, 2008
6ya staff
SOURCE:
Mx2600n is having paper jam BTW the black and white roller before the Fuser unit
There are a number of reasons why the paper would jam at registration. First off, if the paper is completely flat & straight it is probably a feed issue or paper detect issue. There are 2 little black photo reflectors before the rollers in the centre of the feed path. These sensors can get covered with paper dust & may need cleaning. Also try feeding paper from the manual feed tray & see if it jams. If you have jams from both cassette's & manual feed then its most likely a sensor of feed issue. If its from one tray only then the sensors in the vertical path may be dusty with paper dust or worn pick up & feed tyres. There is also an issue with the feed clutches in the paper pick up drive unit which can fail & have been upgraded.
Secondly, if the paper is Z folded at the registration rollers but before the fuser then it could be the primary bed drive gear. This gear also drives the secondary belt unit located in the right hand door assembly.
Hope this helps.
Dave.
Jan 11, 2017 | Sharp Mx2600n Color Copier, Printer,...
06 T & C replaced left rear speed sensor and ABS module, scanner still shows left sensor at o mph all the time
you need to check for voltage to sensor from module or a broken wire,also with a multi meter check for resistance from sensor from turning wheel
Dec 17, 2009 | 2006 Chrysler Town & Country
HI THE CHECK ENGINE LIGHT IS ON IN MY LINCOLN TOWN CAR 95. THE CODE SCANNER READS "TOO LEAN" WHAT THAT MEANS? AUTOZONE PEOPLE IT SAYS THE 02 SENSOR IS BAD, IS THIS CORRECT??? THANKS.
what code did they give the code will tell u something like "o2 lean bank ? sensor?" and if auto zone is telling u that its giving an o2 sensor problem most likely thats the trouble code that showed up and which sensor
Oct 21, 2009 | 1995 Lincoln Town Car
Blower motor doesn't come on. Traced electrical signal to a module on the firewall. Is this the control module? Does the temperature sensor affect manual operation as well?
That is a BSC, or blower speed controller. This is a very common concern, in most cases if you simply wiggle the harness the controller will start to work.
This should be located on the a/c case under the hood below the heater hoses.
Oct 20, 2009 | 2001 Lincoln Town Car
9080c fails to scan single page; has trouble scanning a batch.
Hi
what size page are you trying to scan, if they are smaller than the gap between the transport rollers, they will not feed.
the single sheet problem you have:- the scanner knows when there is paper to feed when the sensor is pushed up beside the pick roller and it will put the tray down again when the rollers are pushed up. sometimes the little plastic sensor to the left of the roller gets a bit stuck and needs to be freed, it wares itself out where it hinges inside the cover around the pick roller. just unclipping it and cleaning it is usually enough.
good luck.
Oct 07, 2009 | Canon DR-9080C Path-Through Scanner
Maf sensor
the maf is located on a black plastic pipe 50mmdia beside the air filter (the air filter is located in a black plastic box 300mmx150mm approx)the maf is held in with two screws
May 04, 2009 | Volvo S40 Cars & Trucks
Engine check light comes on
Have you tried disconnecting the battery for half an hour to reset the computer? If that doesn't work I think the Vacuum Pressure Sensor is in the black box with all the vacuum hoses going to it beside the air filter housing. Not sure tho, subaru will tell you where it is & how to test it if you ring them & ask for the workshop.
Apr 09, 2009 | 1999 Subaru Legacy
THAT DAM RED LIGHT THAT WON'T GO AWAY ON THE SCANNER
Most often this is due to a dirty sensor or reflector. dust will often build up over time and cause poor sensor readings and thus a red error light. There are four paper sensor sets on this scanner. Cleaning each of the sensors with canned-air should resolve this issue.
  1. the small black rectangle that is set down inot the paper-feed tray - this is the paper sensor.
  2. whe you open the scanner (like you would to clear a paper jam), on the part of the scanner that swings open and just above the two white plastic rollers, you will see another small black rectangle that has two "eyes" - this is the wait sensor. the wait sensor meets up with a shiny reflector when the door is closed; this reflector is just behind the large rubber roller on the base of the scanner - it may also build a layer of dust and need to be cleaned.
  3. a little further down on the open door, below the wait sensor is the start sensor, and it's reflector is on the base of the scanner just below the second set of small rubber rollers.
  4. the ending sensor is a little harder to get to. if you look into the area where the paper exits the scanner, you will see two blck rubber rollers - between these rollers you will see a "notch" - at the bottom of the notch is the reflector and just above is the ending sensor. this is the most likely cause of your troubles and usually a few strong blasts from the canned air will take care of it. If the reflector is real dirty, you can take a cotton swab and a few drops of rubbing alcohol and work it around in that area.
This is one of the most common scanner-error questions I get! I hope my wording is clear and helps you resolve this problem!
Aug 22, 2008 | Panasonic KV S2045C Path-Through Scanner
ADF Peripheral cover open M4097D problem
This may help:
I don't have a Fujitsu, but a M/F is a M/F, all fairly similar.
On my SAMSUNG CLX-3170FN, I lifted the ADF cover, which is the smaller cover on top of the ADF, found a small black wedge-shape plastic arm which protrudes through the center, upwards.
As this peripheral ie, envelope / postcard / non-standard stationery cover is lowered, it pushes this arm to activate a limit switch, hidden under plastic of ADF.
If the cover is looseor not properly closed, the gearing and roller-feed mechanism can't push paper through, so causing an error.
The reason it refuses to scan is probably a cover not pushed down, or the sensor limit-switch misbehaving.
Renewing the limit should be fairly simple, if similar to mine.
1: Raise the peripheral cover.
2: Loosen 4 screws holding peripheral base-plate.
3: Switch is visible.
Nov 20, 2017 | Fujitsu M4097DVRS Path-Through Scanner,...
Kodak i65 Logo
235 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
