Question about Bissell 3750 Lift Off Bagless Upright Vacuum
Our cleaner has recently started making a sound like an air raid siren. We have cleaned all filters no difference the noise is terrible.
    President:
  • 1,653 Answers
Check the drive belts for wear and tightness and make sure that the front brush(es) are clean and free of all hair and fabric. This will normall cure the problem
Posted on Nov 14, 2009
Check the complete air way. Probably something stuck in the passage. Start from the bottom plate. Usually jammed where the airway does a turn.
Posted on Nov 15, 2009
I have a kenmore intuition with power flow. I just put a new bag in it and the check bag light keeps coming on. After running it for about a minute it makes a terrible sound. How do I fix it?
Try removing and cleaning (or replacing) any filters. Check that there is nothing that is restricting the suction flow by making sure that hoses and inlet and outlet to the dust collection area (in your case the bag) are all clear. Basically for a vacuum cleaner to work at it's optimum, air needs to be drawn through the system and ejected with the least amount of restriction as possible. Obviously exhaust filters are needed so only clean air is ejected and pipes need to be clear to pick up the dirt and these do block over time. One of the biggest culprits for blocking are products like Shake 'n Vac as very fine particulates can pass through bags, that is why filters are used.
Jul 23, 2015 | Kenmore Vacuums
I cleaned the filters on my dc 25, after cleaning it started to make a whistle noise. Opened the ball will running and touched the filter and noise stopped. Do I need to replace filter or rubber gasket...
You are hearing the air whistling past the gasket. Touching it may make it come and go. It is a small air leak bypassing the filter. It is more of a nuisance than anything. A bit of fine dust may be getting past the filter too so It's best to try to adjust it so it does not make the noise. If your filter was still wet or is clogged it will cause a restriction which makes it more likely for the air to try to get past the filter because it is having a hard time going through the filter.
Sep 01, 2013 | Dyson DC25 All Floors Bagless Upright...
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
My dyson d14 animal keeps cutting in and out. When it's on, the hole above where the filter is, keeps making a loud suction noise and it won't clean up hair and dirt.
Vacuum Cleaners require AIr-Flow. Your machine is not getting any air-flow. The noise you hear is a valve opening up to prevent your machine from overheating and burning out the motor.
You probably have an obstruction somewhere in the machine. Dysons are kind of known for that in the vacuum cleaner world.
Check all air channels and clean them out. If that fixes the problem you still might have issues that caused it to clog up.
I posted the part second because it takes 24 hours to complete it.
Be sure you wash your Washable Pre-filter. It needs to dry for 24 hours. Never put it back in the machine wet.
Once it is completely dry reinstall the pre-filter and your machine should be back to normal operating functions.
Let me know f this helps.
Dec 31, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
Why does the Eureka capture plus pet lovers put off a loud tornado siren sound when you turn it on. I cleaned the filters checked everything and it sounds like a tornado siren in the south. Email...
I would check your fan and see if any of the blades have been fractured. I had this happen recently when my vacuum caught a screw and the sound and vibration was deafening.
Dec 22, 2009 | Eureka Vacuums
I have two older Filter Queen (brown vacuum cleaners). Besides unclogging the hose area and making sure it is not filled with dirt, what else would cause the machine to run hot and have a high pitched...
High pitched sound is often caused by air leaks in air ducts. This will also cause hoover loosing sucking power and slightly overheating.
If the hoover is overheating a lot, then noise can also come from the motor. In that case the part must be rplaced.
Try replacing the cone filter, the secondary filter, and the insulation at the top of the machine.
If that does not fix the problem, then the hoover must be taken apart to clean or repair the air duct.
Nov 13, 2009 | Filter Queen Majestic Canister Vacuum
Envirovac kicks debris back at my feet and is loud
It's clogged!
Many so-called "environmentally friendly" vacuum cleaners have multiple stage filters; the usual configuration is a standard filter followed by a HEPA filter or equivalent. Standard filters can be a paper bag or a bagless, removable container.
From time to time, the secondary filter will get clogged, so it doesn't matter whether you change the bag or empty the container, performance will not improve.
If you have access to compressed air, try removing the secondary filter and blowing it clean with a high pressure air nozzle. If that doesn't work, check the hose to make sure it's clear. If you are using a rug beater attachment, make sure it has not clogged at its inlet.
Sep 06, 2009 | Eureka High Filtration s Mighty Mite...
Vax 2400 performance pet overheating
Unfortunately there is no permanent solution.It is a terrible vacuum cleaner and im getting rid of mine today. I have been maintaining it for 6 months cleaning filters , swapping filters, swapping carbon brushes all to no avail.Dump it. it would'nt **** the air out of a balloon.
Jan 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Kenmore Progressive Direct Drive Upright - noise and bad suction
Had the same problem tonight. Took the entire thing apart only to find there was a much simpler solution. Check the small hose that runs from the brush rollers where the longer hose (on the back) attaches to the side of the vacuum. Easiest way to do this is to lay the handle down and stick something (coat hanger worked good) through it until it comes out of the head. I found a pretty good sized fuzz plug in mine. As soon as I removed it, everything worked great again - and no noise!
Mar 15, 2008 | Kenmore 31912 Progressive Direct Drive...
High pitch
Sounds like you have a clog. Make sure the filters are clean, replace if it has been more then a year, check the inlet down by the brush roll, your clog maybe there.
Dec 24, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Bissell 3750 Lift Off Bagless Upright Vacuum Logo
281 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
