Question about Pentair 3hp Whisperflo Pool Pump In - Ground
I have a Shasta pool from 1996. I replaced the
I have a Shasta pool from 1996. I replaced the plunger and the pool seemed to loose it's suction. I've tried filling the lines with water and I can't get it to start sucking water from the pool. The motor seems to work fine.
  • 366 Answers
Either you have an air leak somewhere on the suction side or your impeller is very clogged. you can fill the pump with water and turn it on, it should try to pick up prime, right when it starts to pull in some water turn it off and try to listen for air leaks or water squirting out somewhere on the suction side. Also, remove the pump basket and try to feel the impeller to see it there is any debris in it. the main cause for a clogged impeller is a cracked or broken pump basket. Also, if the pump has run dry for any period of time, the threaded fitting on the suction side of the pump can shrink and cause a large enough air leak to keep the pump from priming.
Posted on Nov 14, 2009
How do I remove elbo/check valve on ec65. Seems to be really stuck on.
the main drain should be on suction side of pool system (unless it was converted to be a return for safety reasons) since it is on the suction side of system, it is impossible to have DE entering pool at this point.
May 10, 2015 | Hayward EC65 Extended Cycle DE In Ground...
Loosing pump suction when vacuum pool
keep out all the air inside the lines. When Pumps loose power suction is because there is some air inside the lines.exaust the air inside the lines
Aug 08, 2014 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
Our aquabug will not sit entirely on the bottom. It keeps lifting up on one side & doesnt move' What is going on? It seems like we have plenty of suction.
This sounds like a problem with the pool cleaners shoes being worn. If the shoes become worn, it can cause the seal to the pool to become loose, even if you have enough suction. Try replacing the shoe on the side that is lifting (and both sides if they appear worn) and see if that corrects the problem.
Sep 20, 2011 | Hayward Aquabug Above Ground Pool Cleaner...
Moves slowly and the stops. looks like diapham doesn't open back up
This seems to indicate insufficient suction from skimmer. Confirm that all other skimmers are closed off properly. Suction can be checked by disconnecting suction hose from pool cleaner and placing your hand over the end of the hose. Suction hose may also have an obstruction which will inhibit proper operation.
Nov 28, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Zodiac pool cleaner stops and starts and sometimes just stops working completely. Checked diaphram. replaced it with a new one. pool is forever getting green ... at my wits end... bout to pull my hair...
With these pool cleaners, there are several things that can cause a lack of suction and movement. Make sure that the main drain and all suction lines are closed except the line you are using. Make sure there is no debris in the flapper or filter that could be clogging suction. Check the hose are ensure that there are no leaks. Check the pump basket for looseness, cracks, and worn or missing o-rings.
Aug 21, 2010 | Zodiac Pacer Pool Cleaner
Intake to filter has little suction
If you are still looking for some solutions, here they are.
Start by plugging both your out put and input in the pool
or simply close the plungers
If you are uncertain the flow sensor is ok then blast it out with the garden hose. Make sure it swings freely
now take out your cartridge and blast it too
now remove your hose from the inlet to the pump
even though you may be skimming and things go in the basket hair still gets through and cloggs up in front of the filter
this also will happen with out a skimmer
Put it all back together and now open the top bleeder on the cartridge cover
open outlet side hose first
when water starts comong out the bleeder open the inlet hose
now turn on pump for 30 seconds and then close the bleeder
This should do it
Please remeber to rate this solution
Jul 17, 2010 | Intex Automatic Salt Water System for ...
The vacuum seems slower and doesn't get around the whole pool. Is there a way to speed it up
If it's a suction cleaner, give it more suction. Clean the filter and adjust valves to give correct suction
Feb 25, 2010 | Hayward 3/4hp Super Pump Inground Pool...
I replaced my hayward northstar pump housing o-ring. Now I can't get it bacin the pump housing. I lubed it up with pool gasket lube, but I can't seem to even force it back in, so I can turn the pump...
The first pump housing O-Ring I bought was from Leslies Pool Supply and was an after market part. I was the right size, but the rubber was too hard to allow it to compress and slide into the housing. I got the Shasta brand replacement part and the pump housing slid right in!
I guess stay with the original manufaturers parts to assure top performance.
Mar 21, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pentair 3hp Whisperflo Pool Pump In - Ground Logo
156 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
