Question about Kenmore 24032\24036 Top Load Washer
Sears washing machine(model # 110.92575110). Anyone know the capacity. The manual doesn't say
SOURCE: Sears Front Loading washing machine Model 45991 400
go to wwww.managemyhome.com and look for Search Product Manuals on the home page. Input Kenmore as brand and 45991 as model.
Posted on Oct 02, 2008
EllaWatson25
  • 725 Answers
SOURCE: oil leaking on kenmore model 110
This is probably transmission fluid leaking out. You can fix it. Depending on the age of the unit and how much you are willing to spend on a unit that age. Call us for parts. 972-859-0929. We ship next day air and nationwide. Hope this helps you.
Posted on Aug 28, 2009
  • 1937 Answers
SOURCE: i need a technical manual for a sears elite
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=11026922502
Also see the Whirlpool service manual for these washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If it neither agitates nor spins, the first place to look is the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft.
Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Nov 02, 2009
sonicboomele
  • 1557 Answers
SOURCE: need dimensions or load capacity for this model
you should not wash more than 4 kg of cloths at a time. i have asked for a manual to be sent to me and will forward it to you when it comes into the shop
best of luck
Posted on Aug 02, 2010
Testimonial: "thanks!! now i need to find a converter, we work in pounds where i am.. lol where are you from?"
blueextc3221
  • 15935 Answers
SOURCE: Sears / Kenmore top-loading washer does not dispense bleach
Remove the tray and check the proper operation of the solenoid for the door.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Kenmore instruction manuals
The Sears site has many of the manuals in PDF. Know your model number (open the door, look upper left corner on machine) and it will go quicker.
Jul 21, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
I want a manual for My Kenmore HE4T Front Load Washer
This site has lots of manuals. http://www.manualslib.com/products/Kenmore-He4t-110-4508-3024385.html#.VPmnI5cyiQE.mailto
Feb 14, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Taking washer tub out of sears model
Please check on this link for tips to remove the tub: Removing Drum
Jan 11, 2013 | Washing Machines
Need dimensions or load capacity for this model
best of luck
Aug 02, 2010 | Kenmore Washing Machines
What capacity is our Kenmore washer & dryer?
Use the sears parts website, and you can download the manuals for both machines that will tell you.
CLICK HERE
Dec 04, 2009 | Kenmore Washing Machines
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Capacity
Hi there, I have the same washing machine. since it's 2002, Kenmore does not have the info.. I just called sears and they said the capacity is 3.2 Cu Feet. That translates to 19lbs of clothing.
cheers,
Joel
Aug 01, 2008 | Kenmore 43142 Front Load Washer
Size of washer
Size varies between manufactures, the biggest I have seen is the GE which is 3.5 cu ft, base your machine on your standard size load, ours is about 8lbs however I dont overload, I take large items quilts, comforters etc to a laundromat, its not worth breaking my machine over a comforter wash for $3.50 American.
Go to Sears.com and look @ the washers available
Jun 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine. ......Model 25842400
You can go on to sears website to Manage My Home and pull up your manuel for free. Just have your model number.
Apr 30, 2007 | Kenmore 25842 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
275 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
