Question about Palm Treo 650 Handheld
Call forwarding with Treo 650
I cannot change the default number of rings before the call is forwarded. Could do so with my previous cell phone on the same carrier, Centennial wireless. It rings many times, so long that callers often hang up before the call is forwarded. Any ideas or software solutions?
    Sniper:
  • 55 Answers
Call forwarding is not controlled by the device itself, but the switch which is serving your cell phone. Most carriers have a start code to change the number of rings before forwarding usually *74 send then press the number of second before forwarding each ring is about 3-5 seconds or something to that effect. If you contact your carrier they should be able to tell you.
Posted on May 02, 2008
6ya staff
SOURCE:
How do I increase ring time before phone transfers to voicemail
Which phone are you using - please be specific.
Generally Go To Settings > Call Settings > Additional Settings / Call Forwarding Settings > Voice Calls > Change the always forward Settings, here it will ask you for Number of Rings Before Forwarding. Change that as per your convenience.
Sep 19, 2014 | Samsung Cell Phones
Express messenger number of rings
This is a "Class Of Service" function. The out-ot-box default setting is generally 3 rings. However, different extensions can be set to each forward to VM after differing number of rings, but each phone will need to be assigned its own specific Class Of Service and the Call forward timers defined accordingly in those classes of service. Normally your system manager will define several classes of service with different forward-no-answer timers then assign those COS to people who request specific call forward timing. The default is usually 3 rings. Hope this helps
Mar 10, 2014 | Mitel Superset 4150 Phone
How do I get my home phone number to ring on my cell phone while I am on vacation
It's called "call forwarding" and the procedure varies from company to company. With many, dial * 7 2 on your home phone, then at the second dial tone dial your cell phone number. Answer your cell phone when it rings to confirm the call forwarding. To cancel call forwarding when you return from vacation, dial * 7 3 on your home phone.
If the above doesn't work then contact your landline telephone company for their instructions regarding call forwarding.
Aug 01, 2013 | Computers & Internet
Set number of rings before voicemail iphone
This procedure allows your iPhone to ring for longer or shorter periods than the default setting of 20 seconds before voicemail answers. *** Attempt at your own risk but if you pay attention to the keys you input and follow the directions you should have no problems.
1. On your phone, dial *#61# and click Call
The screen will display:
Setting Interrogation Succeeded
Voice Call Forwarding
When Unanswered
Forwards to +1xxxYYYzzzz
Enabled
2. Write down the xxxYYYzzz number (including +1) - this is the number to your voicemail.
3. In order to make the + appear on the keypad in the next step you'll have to hold Zero down for a few seconds, then it will become a Plus (+). Dial **61*+1xxxYYYzzzz**30# and hit Call. +1xxxYYYzzzz is the number you wrote down previously, 30 is the delay in seconds. The delay can be set in 5 second increments, 30 is maximum.
4. Dial *#61# to verify that the new settings are active.
5. Verify working voice mail.
If you find you or your contacts are not being forwarded to your voice mail you have incorrectly altered your voice mail forward number.
To find out what it is and try again:
Dial ##002# and send. This will reset that forward number to factory defaults.
By then Dialing *#61# you will again display the your current (default) voice mail forwarding number.
Return to step [2] and continue.
*** Use this tutorial at your own risk ***...and if you have the time you can always give AT&T a call to have them change the number of rings on an incoming call before Visual Voicemail kicks in. I was able to quickly change the duration on my own, using these diagnostic iPhone GSM codes. The default time duration before Visual Voicemail intercepts the call is set by AT&T to 20 seconds. You will be able to add another 10 seconds yourself, but if you want your callers to wait more than 30 seconds before voicemail picks up then you'll need to contact AT&T technical support - they can change the duration to 45 seconds upon request.
Dec 19, 2010 | Apple iPhone 3G
Can I divert calls from this phone to another phone? Thanks MArk David
  • Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
  • Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
  • Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
  • Switch on the "Call Forwarding" slider. The default position is off.
  • Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
  • Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
  • Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
  • Oct 08, 2010 | Panasonic Cell Phones
    Hi there, my office phone (Samsung officeserv - DS-5007S) series has lost its voicemail option, like it just ring and rings and rings, do you know how to change this and activate the voicemail? or have it...
    Hi I have posted a video for you which shows how to forward calls, you need to find out what the Voice Mail number is, so that you can set the forward to this number. there are various options for forwarding, 'All Calls' and 'Busy , No answer' are the best options, if the one uploaded is wrong chech out 'abbeytel' on Youtube where you will find the right one. Just to note that if you want to forward to your cell this is no problem. Further info vist www.abbeytelecom.com
    Sep 10, 2010 | Samsung Prostar 816 Phone
    Passcode
    The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
    Hope I helped Dr Reed
    Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
    Samsung SGH-D807
    1. On your phone, dial *#61# and click Send.
    2. Some information should be displayed: number that the calls are being forwarded to and the delay before the forwarding engages.
    3. Write down the number (including +1)
    4. Dial **61*+1xxxyyyzzzz*11*30# and hit Send. +1xxxyyyzzzz is the number you wrote down previously, 30 is the delay in seconds. The delay can be set in 5 second increments, 30 is maximum
    5. Dial *#61# to verify that the new settings are active.
    Feb 03, 2009 | Samsung SGH-d807 Cellular Phone
    Palm Treo 650 Smartphone
    Check out what is available on the Palm website: www.palmone.com
    Go to support, downloads, then pick your model (Treo 650) /and/ your service provider.
    Mar 05, 2008 | Palm Treo 650 Handheld
    Palm treo 650
    The 650 seems to have a delicate headphone/mic jack. Dropping the phone, even gently, seems mess up that jack. I returned my first treo 650 as defective, and got a new one. The same thing happened to my new 650 after I simply compressed the phone in my breast coat pocket by holding my mail against my chest.
    I can't get a new one because the replacement treo comes with no warranty of any kind. :(
    My advice would be to find a PDA/phone repair service to repair the jack or diagnose the problem if it turns out not to be the jack.
    Jan 12, 2008 | Palm Treo 650 Handheld
    Palm Treo 650 Handheld Logo
    107 people viewed this question
    Top Palm Computers & Internet Experts
    Ekse
    Marvin
    Marvin
    JC Meredith
    JC Meredith
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
