Question about Canon Office Equipment & Supplies
No paper cassette has been found .....thats because i lost my paper cassette . how can print more foto without paper cassette?
Printer is not printing the black colour when i load the paper from the rear slot...
Hi
try printing a "Nozzle check" to confirm that both your black cartridges are working ok. One cartridge - the smaller (photo) one is used for printing photos on glossy paper. The second - bigger cartridge is used on plain (copy) paper. Sounds to me like your smaller (photo) black cartridge is not working. It's either empty or may need "Cleaning" or "Deep cleaning". In case you don't know...Nozzle check, Cleaning etc utilities can be found on "Maintenance" page in "Printer properties".
good luck
Lumir
www.inkbank.com.au
Mar 07, 2014 | Canon PIXMA MG5320 All-in-One Printer
Alarm light
Paper Jam:
Clear the paper jam.
If the printer does not automatically resume printing, press the control panel button.
No Paper/ Misfeed:
  • The paper cassette may be out of paper or not properly installed.
    If it is empty, load a new stack of paper into the paper cassette.
    If there is paper in the paper cassette, make sure it is straight.
    If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
  • Reduce the amount of paper in the paper cassette, and then try again.
  • Make sure you use paper that meets Brother's recommended paper specifications.
  • Re-install the paper properly, and then press the control panel button. The printer will start printing again.
May 06, 2013 | Canon PIXMA MP495 InkJet Printer
Cannot print. cassette does not have size of paper windows xp
Hi there, you will have to open the print driver, and set the paper size there.
Go start, settings, printers and faxes then double click on the Toshiba, that will open the print que.
Now click on printer, then click on properties, when the properties is open press on Printing Preferences, the paper paper tab on the top of the task bar of printing preference.
The auto cassette, the first cassette and the bypass must be set to the paper that your machine is set to.
Now apply the settings that you have made. Now go to advanced and then Printing Defaults click on Paper tab and change that paper size to the size that you entered for cassette one.
Run a test print and all your problems should be sorted out.
Apr 09, 2011 | Toshiba e-Studio163 Copier
Problem with Canon Pixma 4300 inkjet. Orange alarm lamp flashes 10 times on switching printer on. Have tried plugging and unplugging power cord, and checked that there is no paper jam. Please help. Brian
Hello Brian,
I found the following on Canon's website.
Not sure if it will fix your issue but thought it might be worth a try:
Ten flashes:The Cassette is not installed properly/Cannot perform duplex printing
  • When loading from the Cassette, install the Cassette properly and press the RESUME/CANCEL button.
  • When performing automatic duplex printing, the size of paper may not be compatible with automatic duplex printing. The sizes of media suitable for auto duplex printing are A3, Regal, 11" x 17" (Tabloid), B4, A4, Letter, 10" x 12", 8" x 10", B5, and A5". Make sure that the size of the paper loaded in the printer is correct. Pressing the RESUME/CANCEL button will eject the paper and restart printing from the front side of the next paper. The reverse side of the ejected sheet will not be printed.
Best of luck
Regards
Mar 02, 2011 | Canon Office Equipment & Supplies
Wont print ready light and alarm light flashing
When the printer "Ready" and "Alarm" LEDs flash as shown, please check the following points:
1.Paper Jam: Clear the paper jam referring to "How do I clear paper jams?"
2.No Paper/ Misfeed:
-The paper cassette may be out of paper or not properly installed.
-If it is empty, load a new stack of paper into the paper cassette.
-If there is paper in the paper cassette, make sure it is straight.
-If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
-Reduce the amount of paper in the paper cassette, and then try again.
-Make sure you use paper that meets Brother's recommended paper specifications.
-Reinstall the paper properly, and then press the control panel button. The printer will start printing again.
Dec 06, 2010 | Brother HL 1430 Laser Printer
Hp laserjet 4520n: Attention indicator is blinking, printer is not printing showing paper jam in tray 2. No jam actually !!!
Look at the feed rollers.
If you pull the paper cassette out and look into the now exposed area, you will see two rollers in the machine, just above where the roller in the front of the paper cassette was positioned.
If these rollers are worn, they will not grab the paper and pull it out of the paper cassette. This will cause the machine to think that there is a paper jam, even though no paper is found in the machine because the machine is looking for the paper via a paper path sensor in the front of the machine, just a few inches up from the paper cassette.
Look closely at these rollers... they should have a "rough" surface. If any of them are smooth, you will have to replace them.
There are two blue hub rollers and one white roller.
Part #'s:
Blue: RM1-0037-000CN (Qty.2)
White: RM1-0036-000CN (Qty.1)
Oct 25, 2010 | Office Equipment & Supplies
I'm getting an error code of W8102. Can anybody out there tell me what that means??
W8101/8102 - Print media position warning
The paper over the platen lies too near or too far from the carriage home position
when fed into the printer.
Cause>
The paper on the platen was too close to or too far from the carriage home position
side when paper was fed.
<Probable faulty component>
The way in which paper is set, print paper, cassette/cut-sheet feed unit, carriage
unit, encoder sensor unit, linear scale, carriage controller, head controller, system
controller.
<Action>
1. Paper setting check:
Reset the paper if the setting is not correct.
2. Paper check:
Replace the paper when any stains or pre-prints are found.
Straighten or replace the roll media when the roll of paper is ruffled.
3. Cassette unit/cut-sheet feed unit:
Replace the faulty paper feed component when the paper feeding is performed
correctly in all parts except where the error occurred.
4. Check the linear scale:
Visually check the linear scale for abnormal conditions, such as stains or damage.
5. Replace the carriage unit.
6. Replace the head controller.
7. Replace the system controller.
May 18, 2010 | Canon BJ-W9000 Copier
My HP Photosmart D7260 is not printing pictures
Ok! You didn't tell me how old is the printer, what type of paper and what size you tried to print so I'll do my best to help.
Please note:
  • The photo paper cassette cannot be installed when printing on paper loaded in the in tray.
  • The 7260 printer support 5x7 media only when printing from a computer with the printer software installed.
Loading 5 x 7 inch paper in the HP Photosmart 7260 printer
  1. Lift the main cover of the printer, and slide the paper width guide as far to the left as it will go.
  2. Lift the Out-tray and place a stack of paper in the In-tray.
    • Load the paper with the side to be printed facing down.
    • Load paper in the portrait orientation with the shortest edge feeding into the printer.
    • Do not use too much or too little paper. It may be difficult for the printer to pick up a sheet of paper when there are only one or two sheets in the in tray.
    • Use one type and size of paper at a time. Do not mix paper types or sizes in the In-tray.
  3. Push the paper into the printer as far as it will go without bending.
  4. Lower the Out-tray.
  5. Adjust the paper width guide to fit snugly against the edge of the paper without bending the paper. The paper width guide holds the paper straight as it feeds into the printer.
  6. Close the main cover.
Load 4 x 6 inch (10 x 15 cm) photo paper in an HP Photosmart
Use the photo cassette to load 4 x 6 inch (10 x 15 cm) paper. To print borderless photos, use 4 x 6 inch photo paper with a 0.5 inch tab (10 x 15 cm with 1.25 cm tab). This allows the photo to print without borders on three sides and with a small border on the bottom edge that can be torn off.
HP does not recommend printing borderless photos on plain paper. Also, remove any paper from the In tray before inserting the photo cassette into the printer.
1. Lift the top cover of the printer and remove the photo cassette from the sheath.
2. Place up to 15 sheets of photo paper in the photo cassette with the side to be printed facing down. For tabbed paper, insert the paper so the tabbed end goes into the cassette first.
3. Lift the main cover.
4. Slide the paper width guide all the way to the left.
5. Lift the Out tray and remove any paper that is in the In tray.
6. Line the photo cassette up with the far right edge of the In tray.
7. Gently slide the photo cassette into the printer until it snaps into place.
8. Lower the Out tray.
9. Slide the paper width guide to the right until it cradles the photo cassette, then close the main cover.
If the Out of Paper message appears on the computer and the product stops picking up or feeding paper.
Step one: Reset the product
1. Without turning the product off, remove the power cord from the back of the product.
2. Wait 30 seconds and then plug the power cord into the back of the product.
3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
3. Tap the stack of paper on a flat surface to align the edges.
4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
NOTE: Do not load too much paper in the product.
5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.
If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver
The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
1. Open a document in the program being used to print.
2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
3. Click the Paper/Quality tab.
4. Choose the appropriate paper size from the Size is drop-down menu.
5. Choose the appropriate paper type from the Type is drop-down menu.
6. Click OK and then click OK again to print the document..
7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened.
Step four: Clean the rollers
1. Turn off the product and unplug the power cord.
2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
5. Close the access door and plug in the power cord.
6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
If your product is less than a year old, don't worry, HP can trace the product when you provide the model and the serial number and will help you if it is in warranty. No prove of purchase required.
Jan 09, 2009 | HP PhotoSmart 7260 InkJet Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Canon PIXMA ip4000/paper jammed problem
Tackler- I dont think I have a solution but I know that the cassette should stick out about 5cm i.e. the cover just fits on nicely. I found with mine sometimes it needed a firm (but not hard) push in as obviously some sensor was not being tripped and it would just not pick up the paper in the tray. Have you tried using the top down feed? At least if that works you can print (and you can stack up a couple of pages).
Oct 22, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
173 people viewed this question
old marine
old marine
