Question about Carrier Heating & Cooling
The outside fan always running - Carrier Heating & Cooling
  • Carrier Master
  • 43,501 Answers
Either your thermostat is not getting completely satisfied and the unit is always calling for cooling or it is possible that one pole of the contactor is welded fast and not breaking which could keep the fan running all the time. Either way you should have the unit serviced to find out what is going on. If the t-stst is not being satisfied then there are some other possible issues that could be a problem and should be looked at. These could include low refrigerant or holes in the ductwork.
Posted on Nov 14, 2009
Is the condersor fan supposed to run for the same length of time that the compressor run
If the condenser is located outside, & the outdoor temperature is cool, there will be some sort of ambient controller that cycles the outdoor fan off to maintain refrigerant pressures as not to freeze. so to answer your question...not always & depends on system.
Dec 29, 2014 | Refrigerators
Inside blower wont run
Sounds like you need a new board. Their are people out there that will replace the fan relay on these boards, but I have always just replaced the whole board with a new one. These boards can range from around $50 to $300 depending on which board it is. The way we always double check these boards are exactly the same way you have done it, only we use the 120v from the units transformer and bypass the board, if your fan comes on, your board is not sending the power through to the terminals. It would be different if nothing else on your system was working too. I hope this helps and good luck!
Jul 01, 2012 | Ruud Rheem Honeywell Fan Control Board...
Outdoor fan will stop running and compressor overheats and shuts off. it wont come back on til u reset it at the thermostat. the outdoor unit has a new compressor and fan motor.
I realize the outdoor unit has a new compressor and fan motor - therefore - both those components should be ok - however - the fan motor 'should not' be going off - and the fact that it is going off is what is causing your compressor to overheat and shut off.
The reason the fan motor is going off is - it is bad (breaking down electrically) and is going off on the internal overload. If this is the case (a) the motor needs to be replaced or (b) it's possible that the fan capacitor needs replacing; but fan capacitors generally do not cause much problem, and when they do go bad they usually develop an obvious (to the eyes) bulge. If the capacitor has a bulge in it - I would surely change it out -and probably would (as a shot in the dark) anyway - since they are relatively cheap ($10-$15).
In your complaint you say that "the outdoor fan will stop running and compressor overheats and shuts off." If it happens 'exactly' that way then I'm betting your problem will be that the fan motor is defective as mentioned above, with an outside chance of the capacitor being defective, in which case if it isn't the capacitor - you will need a new fan motor. Note: outside fan motors are notorious for being fickle and it would not surprise me in the least to find a fairly new outside motor that is defective. I would check and see if you had any warranty on it.
All that being said - it is also possible that your outside unit has a 'high pressure cut-out switch,' although most units don't have them anymore, these days. However, if you have such a switch - it is possible (very likely) that it is shutting off the AC. Note: a high pressure cut-out switch will 'shut the entire outside unit off,' not just the fan motor. If that is what is happening then there's a good chance you have such a switch.
If it is happening that way, (the entire outside unit stops) then I would try 'washing the outside coil' really, really good and see if it will run ok afterwards.
Note: outside coils are sometimes difficult to get clean - sometimes requiring you to disassemble to some degree in order to make sure you get them clean.
Always, Always turn all power (including inside thermostat) OFF when washing the outside coil.
Jun 07, 2011 | Heating & Cooling
Computer fan running constantly
Computer fan will always run and act as a ventilator to send the heat outside the CPU.
So, don't worry, be cool.
Thank you.
Jun 10, 2010 | Dell Dimension E510 PC Desktop
Thinkpad 2373: boot and freeze problems.
raodonald
If you are having trouble with your fan running it is possible that the notebook is over heating.
Think about when it ran good and when it did not. Was the fan running and/or was it cooler at that time. Also if you are in a place where it is cool outside you might take the system outside in the cool to see if this makes a difference.
If is does work more when it is colder then most likely the fan is not cooling the system properly.
Let me know if you have any more problems or questions
Issken
Jan 18, 2010 | IBM ThinkPad T40 2373 Notebook
Ruud Achiever 10 heat pump - outside fan won't shut off
Definately get this checked out. Some thing has shorted just enough to let voltage "Feed back" and keep the fan running. Could be capacitor, wires rubbed through each other, etc. A reset is a safety that is used when there is an overcurrent or over pressure situation. No reset set for this situation.
There is always an outside chance that if you touch the unit while standing on wet ground, you may get shocked. I firmly believe that something is allowing power to the fan in a feedback condition so don't let this go as it may cause damage to other parts.
Good Luck and let me know how you make out on this.
May 11, 2009 | Ruud UBHC Air Conditioner
Cooling Fan
sounds like to me your motor in your fan is going. that is y your 4 runner ran nice and cool when its cooler outside. the hotter it is outside the harder your fan will work
Apr 25, 2009 | 1995 Toyota 4Runner
2003 Saturn Vue electric fan always running
Check the fan relay, probably in fuse box in the engine compartment. Check owners manual to be sure. I have seen these melt causing fan to run all the time.
Feb 18, 2009 | 2003 Saturn VUE
Always defrosting GE Model 20
clean the condenser coils at the back and make sure the condenser fan by compressor is running if is not running you mightg need to call a tech to trouble shoot it or if you want repl both the motor and main board like i said you might need a tech to trouble shoot it
Oct 16, 2008 | GE Profile PSW26P Stainless Steel Side by...
Heating & Cooling Logo
43 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
