Question about Dell E173FPf 17" TFT LCD Flat Panel Monitor
Dell monitor E172FPT HAS GOT BLACK LINES ACROSS THE BOTTOM OF THE SCREEN HORIZONTLY??
  • 59 Answers
Click the Menu button and use the '+' & '-' signs to select restore factory settings. Check if you get the same line in the BIOS screen, if so then you would need a replacement.
Posted on Nov 15, 2009
Thin black horizontal lines across bottom of screen
Hi there.
I suggest you see my tip on how to fix the lines on your monitor. The fix for horizontal lines is the same for vertical lines. You can read my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Slasher_X
Jul 20, 2011 | HP w17e Monitor
My Dell monitor developed a thin, dark line horizontally across the screen. Within three months, a second line appeared. I can view the screen, but must look above or below the lines at times. Any idea...
this occurs very commonly in all LCD monitors... this is because each and every cells in the LCD monitor are energized by the vertical and horizontal electric fields placed around the frame of the monitor... if a particular field does not gives the power to the associated cells to it, then the entire line of cells will not operate and together they looks like a single line...This is what happened in your case...
have a look at my tips for replacing the LCD screens on monitors, by clicking here....
Aug 11, 2010 | Dell Audio Players & Recorders
When I turned on my computer, it said it was in power saving mode and to press any key or move the mouse. Did that. Now I have a black rectangle in the middle of my screen that says, "Positioning,...
Your Problem Is not in your Monitor Its in your CPU. Your CPU is not giving Display Signal to Monitor that's why Monitor goes to power saving mode. try to open Your CPU and remove RAM Clean RAM Slots and Fix it Again. Try to Boot now.
Mar 11, 2010 | Dell E172FPt 17" TFT LCD Flat Panel...
I have a dell monitor model e172fpt i have power when it turn on has white on the screen and turn on blue and black screen
not a expert just trying to help,,, try a different monitor and see if it works or not,, if you have same problem it is in the computer,, hope this help you
Feb 25, 2010 | Dell E173FPf 17" TFT LCD Flat Panel...
Horizontal ghost lines across screen
Seems that it is an issue with your video card, Please update Driver for Video card and it that does not help, it is the time to replace the Video card.
You can get your driver from support.dell.com and please enter your service tag to download the driver
May 25, 2009 | Dell M781S Monitor
Shadow Lines Across Screen on Dell P1130 CRT Monitor
What sort of shadow lines? I assume you haven't just noticed the two horizontal lines 1/3rd up the screen from the bottom and 1/3rd down from the top from the internal stabilizing wires that all Trinitron CRTs have?
Jan 29, 2009 | Dell P1130 21" CRT Monitor
Screen Appears Blank
Need to replace inverter 20-50 dollars on ebay, lots of tutorials around the web
Oct 15, 2008 | Dell E172FPt 17" TFT LCD Flat Panel...
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Dell E173FPf 17" TFT LCD Flat Panel Monitor Logo
209 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
