2) A screen should appear with it showing a visualization picture and showing the tracks (songs). If it doesn't appear, go to the dashboard scroll across to the Multimedia section and go to Music.
3) Up the top of the screen it says options like "Burn and Rip". Choose "Rip" and it'll copy the songs from the disk onto the 360. Give it time to finish.
4) And it should say your done. And it's saved onto your 360.
To listen while playing; When you are in the game, press the xbox guide button (the X button in the middle of the controller that has the green light) and wait till that screen pops up on the side of the screen. Then Scroll down to where it says (I think it says Music) but you'll see the "Pause, Play and Skip etc... music buttons, and choose "Select Music" and then it'll expand and take you to the music library (In your hardrive) And just choose the song. And it'll take you back to the gamer tag picture, like before, and press the Xbox guide button and you're back to your game - while the song plays throughout.
And it wont take you away from your game. Hope I helped ? Playstation 3ok, you can put music from a cd onto a ps3. heres how. put the cd you want into the ps3 then go to music then go to audio cd. instead of x to view the tracks hit triangle and select copy. the ps3 can take songs from a cd and put it on the hard drive
you can take songs from the computer and put it on a ps3, heres how.
first, you need a flash drive (if ur not tech savvy, its a lil usb thing that holds information. make sure its a decent size ( 1gb would be best but more or less is ok). then go to my computer on the computer and you should see removable disk. click that. now drag and drop all the songs you want to move to your ps3. once ur done, take the flash drive out and put it in the ps3. go to music and select usb device, however hit triangle and hit display all and it will show you all the music files. hit triangle again and select copy multiple and get all the songs you want from the flash drive
and yes, you can download songs from the internet of a ps3, heres how
heres some of the sites i use mp3realm.org yourmp3.net emp3world.com find a song you like and click the song link. when you do, hover over the link and hit triangle then go to file and select save target. certain files cant be downloaded because keep in mind that it needs to be an.mp3 file for it to be directly downloaded and ready to use (and since you cant rename files on a ps3, you can always download it to a flash drive and change the file name on the pc and then put it back on the ps3)
On the Home screen, press the Play icon next to the word "Music" and it will shuffle all songs with the exception of those in the library that have been tagged as Comedy or Spoken Word.
All songs must be in MP3 or WMA format in order for the player to load any of the songs to play. If songs are in any other format (MP4, ACC) they must be converted to MP3 in order to work. Instructions are on the Intova website how to convert music to MP3 if needed. If the songs that are loaded onto the player are in MP3 format when you press the play button you should see a yellow indicator light meaning the music is playing. If this light does not come on there may be an issue with the player. If this light does come on but you still cant hear any sound then the headphone wires may be damaged. If there is an issue with the player or headphones manufacturer Intova will be happy to help get you back in the water. Please contact Intova at [email protected] for further assistance. Thank you.
Play music files - LG enV: At the main screen, press OK to select Menu. Select Get It Now, then press OK. Select Music & Tones, then press OK. Select My Music, then press OK. Select Songs, then press OK. Select the desired song, then press OK to select Play.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music: 1. Off 2. Repeat single Track 3. Shuffle/No Repeat 4. Repeat all Tracks 5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Since you have a MAC, your probably using ITUNES, ITUNES are MP4 format which this unit doesnt play, you have to make sure what your putting on is MP3 audio files:
Here is a guide on how to convert songs to MP3 on ITUNES:
Just bought the JX-MP102 find it difficult to use but was able to download songs from a windows xp laptop - plug the mp3 player into the usb port and turn on just as you would for playing music its screen should light up and the computer will pop up a screen with several options click to start windows explorer and from there you can got to place holding music files and copy them the disk letter which represents the MP3 player. On my machine my main files are on the C disk and a new D disk pops up for MP3 player. I also have a windows vista machine and it also recognizes the player as a new disk drive just like a flash drive. Unfortunately I can the player to work for a few minutes at best right now even with the music files successfully loaded and playing so I may return it tomorrow. Hope you have better luck. rvwill1930
Reset the player once to make sure it isn't a temporary glitch - reset will NOT erase all of your songs.
Press the downward part of the circular ring when the word "music" is on your screen, and see if it will scroll doen to FM; if the word "music" does not appear, press the left side of the circular ring until the word "Music" appears on the screen
You can thank Microsoft for creating Digital Rights Management.
Okay...I'm assuming this is an MP3 that you loaded using the Rhapsody-to-go or other music service that allows for subscription music.
What the MP3 player is telling you is that because you have subscription music and not purchased music, the DRM allows you to only play the song or songs 30-90 days after download. To continue to listen to the songs, you will need to open your Media Manager software (Best Buy Digital Music Service, Rhapsody, WMP11, Media Monkey, etc) connect your MP3 player to the PC, identify the MP3 player through the media manager and tell it to re-authorize your tracks. Once its finished you'll be able to play your songs for another 30-90 days. You will need to repeat this re-authorizing to continue to play the tracks.
