Question about Compaq Presario 5000 PC Desktop
My monitor gets blurry - Compaq Presario 5000 PC Desktop
  • 115 Answers
First You have to check that the VGA cable of monitor is properly connect with the VGA port of the CPU.If its connected prooerly then check the VGA cable at both end that any bending or broken issue of cable.If cable is broken then replace or repair its better replace the cable.
If cable is ok then degause the monitor .for degause go to menu option and select degause option and press the menu option.After that if still blurred then set the colour option in graphich properties.For graphics properties right clicl on desktop /select graphics properties/select color option and set it as per your requirement.
Posted on Nov 14, 2009
My Samsung crt monitor syncmaster 794mg is blurry I use as tv for month and and reconnect with system the monitor became blurry pls help
blurr y means focus out.
Also adjust brightness (reduce and check half an hour if not blur quickly need to adjust focus)
therefore need to getting help by professional technician to adjust the focus preset in the Fly back.
Also need to careful to avoid arc high tension voltage from anode and from fly back.
Also don't turn white balance much . may be monitor display off when power on if turned more. if reduce much monitor will black.
Jan 25, 2016 | Samsung Computers & Internet
Why is my display blurry?
I had a blurry screen last week and too it to IT support. They were able to play around with my software and repair the computer from some of the glitches and viruses that it had. Have you tried getting professional help with your issue? Managed IT Services from InfinIT Consulting
Aug 27, 2015 | LG Studioworks 775N 17" CRT Monitor
Computer monitor has blurry display
If you have another PC in the house, try plugging in your monitor to that PC instead, and see if the issue follow the monitor. If it does, you could do a Factory Reset on your monitor to see if the issue is fixed. You can do this by Hitting Menu button on your Monitor and finding the Factory reset Option. IF the issue is not fixed, you will most likely need a new monitor, you can easily find one online or at a local store for under 100 dollars.
Jul 03, 2012 | Dell Computers & Internet
Blurry Screen
If you're using a VGA cable (a.k.a the blue plug) you'll have to use the Auto-Adjust feature on your monitor.
Jul 13, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
My compaq sr181nx diplay monitor is now blurry
This could be a faulty monitor. Trying plugging in a different monitor to the computer.. If you continue to have the same problem with the second monitor, then it is your video card or on board video that is going out. If the video is fine after you tried the second monitor, then you need to get a different monitor for your system.
Jun 14, 2009 | HP Compaq Presario SR1810NX PC Desktop
My samsung monitor 906BW is blurry
look through the menus and see if you can find an option in there saying "sharpness" increase and decrease it and see if it makes any difference
Mar 25, 2009 | Samsung 906BW LCD Monitor
Re: CTX monitor getting blurry
Hi Beth,
Your focus screen network turn faulty. It can be solved by by passing the original focus screen network to a new assembled focus screen network.
Apr 08, 2008 | CTX PL 9 19" CRT Monitor
Blurry vertical lines
Try changing the monitors refresh rate setting. I had this same problem and fiddled about with the display setting - I found that my monitor had blurry strips across it and the desktop didn't fit the monitor until I changed the refresh rate to 75hz
Nov 07, 2007 | Acer AL1914 19" LCD Monitor
Compaq Presario 5000 PC Desktop Logo
80 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
