Question about GE Washing Machines
Front load washer cloths stinking, will not spin out.
    President:
  • 1,653 Answers
Part 1 of 2
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Nov 14, 2009
I need a service manual for an lg wm2455hg front load washer. Where can i get one?
i have thiswm2455hg unit that is to me worthless it doesnt wash the cloths clean i just go through the cycles and the cloths come out spots and not clean it vibrates on spin clycle the cloths look drye when the machine is washing very little suds this is the last front load im getting let me see the agitator in the water not this front load clonker and it stinks after sitting a couple days whats up
Jun 09, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Strong mildew smell in washer is making cloths & towels smell bad, how do you get rid of the problem?
if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
I use tilex sometimes and do a rinse spin.
Nov 16, 2009 | Kenmore Elite 45986 Front Load Washer
I have a frigidaire front load washer, it and the clothes stink.
I have read that using Nu Fresh in a few of your loads will take care of this problem.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
My GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Aug 09, 2009 | GE WSXH208A Front Load Washer
My washer has an odor like mildewing clothes, but I can't find any.
all front loaders are good for that, none of the manufactures have really found a solution to clothes stinking like that
Jun 23, 2009 | Whirlpool GHW9200L Front Load Washer
MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
Switch from liquid to powder detergent, no fabric softner (I know...I love it too), clean the gasket and run a cycle with bleach only. Leave the door open whenever possible. This fixed my smelly washer, now if it would only spin!
Jun 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Stinky clothes
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 17, 2008 | Kenmore Elite 45986 Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
