Question about Reebok Exercise & Fitness
I have Just purchased a new Reebox irun treadmill. put it on a flat level surface, plugged in power lead. the power button on the side lights up as if there should be power(orange illumination visible), but the main screen doesnt power up at all. just wondering if anyone else has enconutered the same problem? thanks alot Tony
Hi Tony
Silly though it may sound, make sure that you've fully inserted the safety key into the front of the console.
When the key is unpacked it arrives with its cord wound in such a way that it looks like the key can being inserted fine but will actually only actually insert half way in. The safety key has to be fully pushed in for main screen to come up.
Cheers
Joe
Posted on Nov 24, 2009
My reebox I run treadmill switches on, but the belt will not move
You have to check the motor drive. Also check carbon brush of the motor.
If you wish to get some details about treadmill repair then check the following link.
http://electro-medical.blogspot.com/
Jul 20, 2016 | Exercise & Fitness
Error 0
Try making sure that your treadmill is plugged into a dedicated 20 amp circuit, DON'T use extension cords.
Make sure that your treadmill is on a level surface and make sure that your belt is tight.
If this doesn't work, then it will need to be repaired by the manufacturer or returned to the seller for a refund or swap it for another one.
Hope this helps...
May 13, 2013 | Exercise & Fitness
Looking for a reebok irun adapter re- 14301
go to www.fitnessrepairparts.comand get itGod bless you
Mar 15, 2013 | Reebok Exercise & Fitness
Cannot open the running stand on rbk treadmill Iwalk Irun
see the video attached and proceed according. or see your instr. manual how to fold or unfold the treadmill. if you do not have the instr. manual go to www.fitness.manualsonline.com
and download free
Nov 13, 2012 | Reebok 8100 ES Treadmill Save Big!
Irun treadmill not working- blank screen, belt not running but power light on
1) adjust the REED swtich, clean, and tigh the wires connector.
2) After you did the adjustmente RUN the software calibration for diagnose, troubleshooting, and fix it.
see the diagram attached.
Jul 03, 2012 | Reebok treadmill i-run s
My reebok run won't work although the power is on
Dear Sir:
1) Reset the c. breaker from your outlet home.see if some wire is loose.
2) Do not use extension cord, the drop of voltage is not O.K for to keep running the treadmill.
3) Reset your c.breaker or fuse from your treadmill, is to the side of power button.
4) See internal some wires is loose.
5) Test the input voltage for 115 vac with a VOM., IF THERE ARE MISSING, you have problem with the c.breaker or transformer.
see the block diagram for illustration. sincerely. God bless you.
ernesto cuadra
managua, nicaragua.c.a
Feb 11, 2012 | Reebok Exercise & Fitness
Dc greenmaster gmd 82-05-2b how muchdoes it cost and where to buy? reebok irun treadmill motor does not work , need replacement
i want to purchase dc motor 3 hp continues duty 230 v dc power supply and 4800 rpm form my treadmil. please suggest. i am in chandigarh India.
Apr 25, 2011 | Reebok Exercise & Fitness
I have a Samsung LCD TV and it won't turn on
A common problem with samsung flat panel tv's is that the capacitors on the power supply fail.
You will need to remove the back and check the power supply pcb for puffed caps. To do this you will need to lay the tv face down on a cushioned surface and remove all the screws that secure the back of the tv. You will need a surface large enough to support the whole tv. This is to protect the panel. DO NOT place tv on surface where the front of the tv is not supported by the frame.
Remove the back of the tv and check for puffed caps on the power supply pcb. This is the board that the power cord is attached to.
If there are any puffed caps, you will need to replace them with equal or slightly higher valued caps.The value ratings are printed on the capacitors in mfd and voltage.
You will need a soldering iron to remove and replace them.
After reinstalling the power supply and before you put the back on, hook up a power cord to the tv and try turning it on. If you see a backlight come on, the tv is working. Try hitting the meny button and see if you have an on screen display. If you do put the back cover back on.
If tv doesn't power up, then the power supply pcb is probably bad. Try checking the voltage outputs from the connectors on the side of the pcb. Use a digital multimeter, connecting black lead to chassis ground and read lead to check voltage on the pins of the connectors. There should be voltage levels printed next to the connector on the pcb. Let me know if this helps you.
Apr 04, 2011 | Samsung LN52A550 LCD TV
My wife's Reebox 8700 treadmill is NOW stuck on the highest incline. Please help. It's under warranty. Thank you.
The problem is most likely a malfunctioning incline motor. It is still under warranty, therefore you can contact iconservice.com and they will send a technician to your home to install the new motor. Contact them through their website at iconservice.com and they will be able to help you. Thank you for using fixya and please let me know if there is anything else I can do for you.
Aug 17, 2010 | Reebok 8700 ES Treadmill - Silver Service...
Hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
May 14, 2010 | Reebok Exercise & Fitness
Exercise & Fitness Logo
137 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
