Panasonic KX-TGA600B Cordless Expansion Handset Logo
Posted on Nov 14, 2009
My phone says line in use and no dial tone
My phone says ''line in use'' and there is no dial tone.
  • Anonymous Mar 29, 2014
    Cannot get the line clear
gundalf
Level 1:
  • Contributor 37 Answers
  • Posted on Oct 27, 2010
gundalf
Contributor
Level 1:
Answers
37
Questions
0
Helped
14710
Points
44
I also, but my dsl is still functional...
3 Related Answers
Anonymous
  • Posted on Mar 29, 2010
SOURCE: no dial tone and "line in use " message
Try the simple things first. Try a different phone. In my case, I had the phone company check - outside was fine. After two hours my phone worked. I figured out what happened in my case. Both phones were dead (battery). I think one died with the phone off the hook. once the phones were fully charged, the phone worked.
Anonymous
  • 3 Answers
  • Posted on Dec 31, 2010
SOURCE: intercom light stuck on and no dial tone on GE 4 line phone
I bet the problem is that you used to have two phone lines and now you only have one line. You cannot program an extension into one of these phones unless both Line1 and Line2 coming into the phone are working- it will act as if the extension you picked is in use, but the actual thing it is complaining about is that Line2 isn't working. The phones might have been working for years on a single phone line as long as they didn't lose power. But you don't have to throw the phones away just because you gave up your second phone line, you can still make them work. (I did it for a 12 phone system.) The way to to it: make a special cable that connects your single incoming phone line to both L1 and L2 on the phone, tricking the phone into thinking both L1 and L2 are working. Then program the extensions into the phones, and go back to using a normal cable so that only Line1 is hooked up. To make this cable: take a normal male to male cable and cut off one end. Then connect both the black and the green wires of the cut end of your cable to the green post in a standard phone jack (the kind you would surface mount on the wall will work best), and connect both the yellow and red wires to the red post inside the surface mount phone jack. Now you have an "extension cable" that takes your one incoming line to both L1 and L2 on the phone: Now plug your incoming phone wire into the phone jack, and plug the wire you connected into the jack into the back of your phone. The phone is probably already blinking red on the intercom, just push the extension number you want it to have, making sure there are no conflicting extensions already in use.
I would reconnect the phone using a normal line so that only Line 1 is "hot", don't leave it on this double-connected cable any longer than you need to in order to program the extension.
A
Anonymous
  • Posted on Dec 22, 2007
SOURCE: Phone line/phone jack problem
The wiring on the jacks is set up for a 2 line phone.
If you take the jacks apart, you will see either:
A) red, green, and black, yellow
B)white blue/blue white and white orange/orange white
You need to swap the pairs.
If there are red/green/black/yellow wires. remove the yellow/black and move them to where the red/greens are. Then put the red/green wires, where the yellow/black used to be.
OR, you need to swap the orange and the blue wires.
Will not dial out on pulse on one line, works on second line
try changing phone to tone dialing . one phone line has been setup for Decadic dialing and the other line may be setup for tone dialing.
If tone dialing is working on one line but not the other then get phone company to change the dialing type on the phone line.
Dual tone multi frequency is the technical name for tone dialing and is more efficient than decadic dialing or pulse dialing.
4answers
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
2answers
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
1helpful
Hi my canon fax-JX500 displays 'line in use' and has no dial tone. Can you please tell me how to fix the problem?
Unplug your fax from the phone line. Plug in a phone. Dial tone? Yes? then either fax is bad or the phone wire is bad.
No dial tone? Phone line dead.
1helpful
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Handset displays "Line in Use" no dialing tone and
I can't get dial tone either. Let me know if you find a solution please.
Dial tone on speaker-phone but no dial tone on line 1
Either button mapping or no dial tone at the system cabinet. If your desplay sas CO1 and you have no dial tone, go to the sytsem cabinet ans swap the modular plugs for CO1 and CO2. If the No Dial Tone moves, "mus be sumpin wrong wit yo lines".
Carl
Won't dial out
might you have your phone set for tone on a pulse line???
Do you know what kind of line you have?
You can use pulse and/or tone on a tone line. But you cannot use tone on a pulse line.
A pulse line is cheaper ... I have a pulse line from the mid 70's and I refuse to upgrade it (costs more) to tone - whats the point - I never get any calls and im not in that big a hurry to dial for the extra couple bucks they want.
No dial tone
Please disconnect your cordless phones from telephone jacks throughout the home. The "line in use" is say that you have a short on the line, or a phone off the hook. So disconnect lines, then replug 1 corded phone in to check for dial tone. If working, continue to plug in 1 phone at a time(rechecking working one each time) to find the equipment that is causing you heartache.
Phone has a dial tone but will not dial
I would first verify that the line is good. Take a known good corded phone. YES corded phone !!! and try dialing with it and make sure it dials on the line every time. Also make sure that the Pulse/Tone setting is set for your service( there is still a few area without Touch Tone belive it or not)
Once you verify that the line is ok check each phone and take the defective ones back to where you bought them.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
