Hello:The xbox came with an audio and video cable, probably componet cables on one end, if you are going to use HDTV input which is the red/grn/blue cables on the end of you xbox plug them into the corresponding color in the back of the tv, also on your cable is a switch labeled HTDT and TV make sure the switch is in the HDTV mode if you are going to connect the componet cables if you are going to use regular video then make sure its in the other posistion. If you use componet cables you are going to use the red an white audio cables also a total of five cables should be connected to the TV. Some newer xboxs have hdmi output as well this is the better of the three connections as it also has audio and hd all on one cable. using your tv's remote switch the tv's input to the same input you connected your xbox to. HAPPY GAMING..
connect the hdmi as normal , then use the composite cable to the headset and in audio output settings enable audio multi out , that will output audio to both the hdmi and composite audio jacks . click here to download repair guide... u can do this by yourself....
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
It could be a problem inside the Wii where it only outputs a signal through HD. Have you tried a different TV using the original cables? If the problem persists I would recommend calling Nintendo.
Make sure the AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
Connect the other end of the AV Cable into the yellow Composite
port for video, and into the white and red audio ports (if your TV does
not have the red port, simply ignore it) on the back of your TV.
While the PLAYSTATION 3 system is in standby mode (red light on the
front of the system), hold down the touch-sensitive On/Off button on
the front of the system until the system goes into standby mode again .
(So the light cycle would go from: red light to --> green light
--> then back to red light) This will ensure that you have held
down the On/Off button long enough to reset the Video Output Settings.
Turn ON the PLAYSTATION 3 and once the system finishes powering up,
the Video Output Settings will automatically be reset to the standard
resolution (or detect the current display output settings of your
TV/monitor).
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
HI:
You are using a new HD Cable box, that are using componet video cables for HD, Unfortunetly this receiver does not have componet inputs, so you will just have to run the audio from the televison directly to the receiver by connecting the video out and audio out from the television to the receiver's video Input one. This will require a normal RCA composite cables yellow,red,white. Connect one end of each of the cables to televisions output terminals, and the other to the input one on the receiver. Note: Your TV might have a seperate term called Monitor out, Connect the yellow here, and the red and white to audio out. You can do the same for the DVD but you have to use the same cables,Also the television will not display HD picture this way as this is not a HDTV Receiver. If you just want TV sound to the receiver then do not use the video(Yellow) cable just use the audio out terminals from the tv and connect to Input one on the receiver. you can do this with the cable box also but you have to use RCA type cables . If you want the full HD experience then a new up todate receiver is necessary.
