Question about RCA L50000 50" Rear Projection Television
Replacement bulb for an RCA L50000
Was wondering if you could help me with what kind of replacement bulb to get for an RCA L50000
    Genius:
  • 1,694 Answers
Www.bulbsolutions.com .....................................T.
Posted on Jan 08, 2008
Is my rca HD50LPW165 projection bulb replacement a "diy" job? I am aware my projection bulb failed. I priced out the bulb but times being what they are economically, I was wondering the difficulty (and...
Replaceing Lamp is a easy job,just make sure you wear rubber gloves so you do not leave your fringer prints on it, Mats has Lamps for $99.00
1-800-628-1118 Go to Encompass Parts Distribution and look up your Model Number they might have free service manual you can print out online.1-800-638-3328
Jun 01, 2010 | RCA HD50LPW165 50" Rear Projection HDTV
RCA scenium model hd50lpw165. lamp went out- replaced it but tried so many times to turn it on before realizing the bulb needed to be replaced that it locked up. what to do?
http://www.tvtechcenter.com/board/links/rca/ATC311%20Training%20Manual.pdf
OK above is a service and training manual this is what engineers use to teach engineers how to fix sets like yours Use this an you may be able to repair READ THE SAFETY INSTRUCTION FIRST.
Apr 29, 2010 | RCA Scenium L50000 Television
Need a new replacement bulb for a m50wh725, where do i find it?
Go to Encompass Electronics 1-800-638-3328 or Mats Electronics 1-800-628-1118
Oct 04, 2009 | RCA L50000 50" Rear Projection Television
RCA 50" Projection TV
When you have picture, look a the back of the TV and see where light is eminationg from through grill or vent of some sort. When you lose the picture, see if you still have light. If you do, then you don't have a ballast problem you have some sort of Light Engine problem and that will be an expensive fix, but not as expensive as if you have to replace the ballast that drives the back light.
Sep 21, 2009 | RCA L50000 50" Rear Projection Television
I am not getting a picture on my RCA scenium L50000,
Try looking in the instruction book for info about the lamp. That is the most likely cause.
Mar 29, 2009 | RCA Scenium L50000 Television
50' rca projection tv
your high voltage splitter is probably bad, or you high voltage flyback transformer (deflection board). not sure of your model #, is it correct? It may be a lamp but you shouldnt smell burning. You can unplug and let it discharge and find where the burnt up parts are to find your problem. Follow your nose, it always knows!
High-voltage can hurt/kill you.. be very careful
Jan 23, 2009 | RCA L50000 50" Rear Projection Television
RCA 52' Projection TV Model 52W19B Need help with bulb replacement
bulb? what model do you have....is this a d52w19? if this is a rca itc222 chasis unfortunatly it has no bulbs.. it should have tubes and these are not fesable to change
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
PROJECTION TV
WE did the same thing it will eventually dry up
May 03, 2008 | RCA L50000 50" Rear Projection Television
Rca m50wh725 rear projection tv.
It has gone into protection mode. This is caused when a short circuit is detected by the power management system inside the tv. Try a hard reset: Unplug the power cord for a full 4 hours; then try it again and see if it will clear the protection fault and reset it. If the reset does not help you will need to have a tech look at the set and take voltage measurements inside to determine which section of the tv has failed and what components will need replacement. The cost of repair is always over $200 and could be much more, depending on the specific parts that need replacing. If the ICs have burned out the repair is around $400. The flashing of the standby light may mean something, but I do not know the diagnostic code RCA is using; most RCA models do not have any diagnostic blink codes in the set. Hope this helps. Let me know if I can help further.
Jul 06, 2007 | RCA L50000 50" Rear Projection Television
RCA L50000 50" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
