Question about Blanco 511-620 supreme 2 One-Piece Undermount Stainless Steel Kitchen Sink
Hot water Tap would not close off - had to run Hot water system down to unscrew hot water tap fitting - seems the plastic grummet Lock has worn away
  • Mike Linderman
    Mike Linderman May 11, 2010
    Need to get a repair kit for the brand faucet
  • Anonymous Mar 24, 2014
    No hot water comming from hot water tap
  • 3 Answers
Try at ur local plumbers merchant u should be able to get a new insert
Posted on Nov 26, 2009
I have a Whirlpool water heater, the drain valve is plastic and has split into at the hose connection, I want to replace the plastic with a brass valve. How do I drain the water?
Most water heaters have a drain on the bottom where you can hook up a garden hose and run out side. Or you can get an air compressor and hook the air line to an open hot tap and put pressure and run the water out another hot tap. Close all taps but these two and make sure the cold water inlet to the tank is shut off.
Jun 26, 2017 | Whirlpool Water Heaters
Water temperature has reduced even on maximum setting
check tap had a shower myself that would start hot then 3 minutes later hot was cold! then hot after 5 minutes.
I turned off main tap on meter, Undid tap fitting on shower found the washer was worn but also the tap fitting was seized could not turn it for full movement. You could soak the tap screw fitting in CLR and pull apart and use a tap grease on the screw thread or just buy another tap fitting. I discovered most of my tap fittings had calcium build up in them. But I replaced the shower tap valve thingy as it was really seized up.
Nov 22, 2015 | Home
Air lock in hot water tap in kitchen. tap was left running, how do we fix?
connect a hose from the cold tap to the hot and turn on hot tap then turn on cold tap slowly and watch for air bubbles in hot tank header if you have one, but 30 seconds should be enough. turn both taps off then try hot tap for flow, it should have cleared the air lock. You have not stated what type of system you have or if it is a pressurised system. my fix is for the old type copper cylinder and header tank system and not for a pressurised system that are mains pressure fed..
Nov 26, 2013 | JumpUSA Dribble Specs No Look Basketball...
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
My Jura Capresso E 8 is stuck in open tap filling system. I open tap it says filling system, it says close tap, when I close the tap it goes back into open tap. Float valve looks fine, water is moving
Open the tap with frother spout off. This happened to mine and I took the frother tip off and opened tap with tip off. Water filled and I closed tap...Machine returned "Ready". I heated water in microwave for three minutes- placed frother tip in hot water and all kinds of gunk came out. Lesson learned- Do a thorough cleaning of frother by immersing it in very hot water at least once monthly- even if you don't use it
Jan 06, 2013 | Jura Capresso Impressa E8 Espresso/Coffee...
I have to turn the hot water tap on full open to get hot water
Type of water heater is unknown
If you have single-handled faucet the faucet cartridge might be bad.
If you have recirculation system, then check valve might be bad.
Copy following links for troubleshoot.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Jul 16, 2012 | Water Heaters
Heater not getting hot for a 1999 toyota 4runner
the heater switches in the 4 runners can someetimes get jammed because of corrosion inside the tap itself the easyest way to see if its jammed is to locate it behind the engine down near the firewall you will see two hoses running through the wall and one of these will have a tap . looks like a plastic fitting with either a rod with an actuator aarm or vacumm line running to it . witht the engine up to running temperature and the heater on check the side of the tap that runs to the engine for heat . if is cold then the tap is jammed closed . if its hot then you may have a blocked heater core
Dec 13, 2009 | Toyota 4Runner Cars & Trucks
Vaillant combi boiler problem
when the tap is turned on and the water light on the boiler doesn't this means the diverter valve is not operating it could be down to low water pressure in the house this can be checked at the cold tap in the kitchen. if there is plenty of pressure then it could be the diagphram in the diverter valve is worn or split. the diagphram is only a few pounds but it depends on the engineer you get as to how much money he wants to fit it.
the egg timer symbol (or two pyramids together) is an ignition indicator turn off and on again to see if it will fire with the tap running. reset the boiler with the lower right hand control knob.
Dec 31, 2008 | Heating & Cooling
Re pressurise the BAXI DUO TEC COMBI 28 HE A
I represurised mine by the following:
1. unscrew the left hand circular tap all the way
2. slowly unscrew the right hand circular tap untill you hear the water coming through.
3. turn off both taps when pressure is good
Dec 28, 2008 | Kitchen Appliances - Others
Blanco 511-620 supreme 2 One-Piece Undermount Stainless Steel Kitchen Sink Logo
316 people viewed this question
Top Blanco Home Experts
J.D. Browning
J.D. Browning
uggachucka
Level 1 Expert
Tom Chichester
Are you a Blanco Home Expert? Answer questions, earn points and help others
