Question about Makita Saws
Saw cuts out under load - Makita Saws
  • 44 Answers
Motor has prolly overheated too many times from either dull blades or pushing the work into the blade too fast. if you can, remove the motor and have it checked by an electric motor repair shop; don't be surprised if the cost of repair is close to the cost of a new saw. in the future make sure blades are sharp and let the saw do the work to avoid this problem
Posted on Nov 14, 2009
What caused my bosch matter saw to quit cutting in middle of the cut
Several possibles:
1) Load exceeded circuit amps. Breaker tripped.
2) Load exceeded saw amps. Reset tripped.
3) Wiring failure in saw.
4) Wiring failure in supply.
Time to start checking.
Note- if the blade is dull or the load on the saw is too great it will trip one of the breakers.
Mar 26, 2016 | Bosch Saws
Starts but stops under load
Use sharp Chain. If saw has changed climates since previous use, adjust carburetor to accommodate the change, ensure proper fuel mix ratio, check spark plug, and if you still have problem inspect / replace piston rings.
Sep 21, 2014 | Poulan Garden
2 year old TS410 no power recently, was serviced , correct mix but dies when pressure comes on ,blade stops, starts fine and runs idle fine-tom
Hi Thomas its probably had its high/low screws reset and whilst it runs fine on the bench under load its running weak try unscrewing the high screw out a half a turn
Aug 16, 2013 | Stihl Ts 410 420 Cut Off Saw...
My chainsaw starts and runs fine. After a short time cutting it starves for fuel and cuts out. It will still idle. The carb has been rebuilt and no change.
Take it back to whoever did the carb work. There are two jets on those, an idle jet which can be adjusted for idle speed, and the power jet that kicks in when the saw is under work load. You still have a problem with the power jet, either needs adjusting 1/4 turn at a time until the saw stops killing under load, or the jet and assembly is bad.
Apr 06, 2013 | Makita DCS6401 20 20",64cc Chainsaw 2...
D24000 wet tile saw smells of burning. What could this be?
mmm.. motor problem,armature or field coil burned or bearing burn motor housing
Jun 03, 2012 | Dewalt D24000S Heavy-Duty 10-inch Wet Tile...
My saw will cut for 5 seconds and then the blade stops spinning. When I back the blade out it starts again and the process is repeated. It takes a long time to cut wood this way. What's the problem? Is...
I would suspect a combination of the two! You blade probably isn't sharp and your saws brushes are probably getting worn. The brushes are made of carbon and are pushed up against the rotor by a spring. As the brush wears down the spring doesn't put as much pressure on the brushes which means it will stop working when placed under heavy load.
Aug 11, 2011 | Rotary Professional Grade 7.25 Inch...
Chain saw starts, runs for two or three seconds then cuts out
check the carburator mixture, if its running too ritch...it will cut out quickly at idle, if its lean...it will sputter out under load. make sure your oil/fuel mix is of the right ratio as well, all motors are different
Apr 28, 2010 | McCulloch 16" Electric Chain Saw 35 HP
Chain stops under load ms 660 stihl
your centrifical clutch need to be replaced there is no adjustment,I hope this helps you?
Oct 01, 2009 | Garden
Saws Logo
133 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
