Can't get fax set in recieve mode
I have misplaced my manual and can't get my fax set to recieve faxes only to send. could you Plesae HELP me. Thanks in Advance
Sincerely maryann
    Problem Solver:
  • 8 Answers
Please state your make and model. Each make/model has different method of setting.
Posted on Feb 21, 2008
WE CAN SEND A FAX BUT CANNOT RECIEVE A FAX THE PHONE LINE IS CONNECTED TO LINE AND NOT PHONE PLEASE HELP
try setting the answer mode to auto answer. It may be in manual answer mode. Also try calling your fax number and see if it rings.
Feb 19, 2011 | Canon FAXPHONE L80 Laser
Will send but won't recieve fax Lexmark 5600 6600
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 13, 2010 | Office Equipment & Supplies
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
We have dial tone and cant recive faxes but can send them HELP
check the setting on the display hasnt been changed to manual or tel settings it should have a RX mode this need s to be set to auto or fax mode otherwise you will have to keep lifting reciever and then press start button torecieve faxes
Jul 28, 2009 | Office Equipment & Supplies
Sends faxes fine, but will not receive. Message "FAD" on screen
Could the message be reading "TAD"? If you have an answering machine hooked up anywhere on the same line as the fax, you need to refer to page 16 of your manual. Set your answering machine to 2 rings and de-activate the toll saver mode. If you have a dedicated fax line without the TAD, set your fax recieving mode to fax only by pressing the MODE button under the LCD display untill fax only isindicated
Jul 07, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
Can't receive faxes but can send them okay
The easiest thing to check is the recieve mode setting. most of the time when this happens the machine is set on manual recieve. Set it to automatic recieve and you should be fine.
Oct 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Dec 06, 2007 | Canon LaserClass 2060P Plain Paper Fax
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
k24674
jasbo
jasbo
