How do I find the filter on the Hotpoint Ultima WT960P? I want to clean it, but it isn't under the kick strip - or at least if it is, the cover tells me it's an electrical panel...
    President:
  • 1,653 Answers
If I am right this machine is fitted witha self cleaning pump and does not have a filter. If there is no filter under the kickstrip then this is correct. many Hotpoints are now made this way but yiu may still have one so check under the kickstrip.
Posted on Nov 14, 2009
Error code F08 FLASHING WILL NOT SPIN
The pressure switch is stuck and the machine thinks it is full of water. You need to remove the top, look for the pressure switch and unplug the hose on it and blow air through the hose. Then replace the hose on the switch. It looks like this: http://www.yourspares.co.uk/parts/hotpoint/washing-machines/wt960p/parts/ys56011/hotpoint-wt960p-pressure-switch-spares-C00194160.aspx
Feb 06, 2016 | Hotpoint Ultima WT960P Washer Front...
Where is the pressure switch on a wt960 hotpoint washer
usually located in the panel on the left said has a clear plastic tube going into it
Aug 01, 2014 | Hotpoint Ultima WT960P Washer Front...
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
On a hotpoint ultima wt741. how does the plastic outer tub separate so that the inner steel drum can be removed so as to replace the bearings?
2 tubs used on these-one has screw going around the middle of the tub to split in half/the other is a sealed tank which means you have to replace tub-if you have a filter under the front kick strip then its the sealed tub
Nov 11, 2009 | Washing Machines
My Hotpoint Ultima WT960P has developed a very severe vibration under load on fast spin - how can I fix this Tom
hi there....most probable cause is a main bearing failuer..or a cracked spider unit at rear of inner drum.......both scenearios require a comleted strip down of the wash tub
regards Sir Galahad
Aug 16, 2009 | Hotpoint Ariston AW125 Front Load Washer
How to clean the filter
the dryer filter is in the dryer box on top of the drum, under the lid of the machine at the rear, sometimes has a grey hose going into it, the box will have to be removed and split to access it.
the wash filter will be either at the front of the machine behind the kick plate or at the rear behind the lower panel attached to th bottom of the drum.
Feb 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wt960p hotpoint
The error F05 indicates that the pressure switch is jammed on full.
The only thing you can do your self is to check the filter is not blocked.
Remove lower rear panel of washer, locate and remove large black hose fatened to bottom of tub, watch out for water running out.
Remove and clean plastic filter inside hose.
Refit filter and hose, test for leaks.
If problem still persists, then could be faulty pressure switch or blockage in the pressure system.
Let me know if you require any firther info.
Pleas rate my solution.
Thanks.
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
273 people viewed this question
Top Washing Machines Experts
