Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Dryer. Will not start when drying setting dial is pulled out (which is the way in which to start). the dampness light illuminates when pulling the dial, however the dryer will not start?
  • 619 Answers
SOURCE: maytag atlantis will not turn off
the control panel wiring open need to reconnect.
Posted on Jan 01, 2008
  • 4 Answers
SOURCE: maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Posted on Nov 01, 2008
  • 16 Answers
SOURCE: Dryer won't start when knob is pulled.
If you push the knob to the left and it makes a good contact and starts the machine, then replace the timer switch. Write down the Name and Model Number of the machine (usually on or below the door)
take it to a local appliance shop and order a new part. When you recieve the new part UNPLUG the machine and remove the three screws from of the top of the electrical compartment and gently pull o the front open, there is only one plug attached to the switch, remove it and dislodge the old switch, then snap the new switch in place and replace the plug, close the compartment and replace the three screws, plug in the dryer, and try it.
Posted on Apr 11, 2009
Healeyman
  • 1198 Answers
SOURCE: Maytag Atlantis Dryer squeals
Try Repairclinic.com for help and parts. You are going to need heat resistant grease, and probably snap ring pliers.
Posted on Apr 28, 2009
SOURCE: Maytag Atlantis MDG8400AWW Dryer Runs Cool
I had a similar problem years back. It was the ignitor. The ignitor is a ceramic like piece that heats up (glows red) that ignites the gas. Typically when that goes, you will see some white residue build up where it cracked, thus breaking the electrical connection. This thing works like a heating element on an electric stove, but rougher looking.
The part was about $30 at my local parts store. I bought an extra one just in case so I have it on hand. I installed it with common tools.
You can check it to see if you lost connection by using a volt meter.
Good luck.
Posted on Jun 23, 2009
My Maytag Atlantis MDE7400AYW does not start when I pull the knob and I cleaned the sensor and connection and pulled the panel and checked the connection on the board the damp indicator light comes on but...
There are a few different scenarios which would cause the dryer not to start. First, make sure you door switch is functional. Second, the white thermal fuse, located on the exhaust housing may be open. Worst case scenario would be a defective timer or motor. Either of these may not be cost-effective to replace.
Mar 06, 2014 | Maytag Atlantis MDG7400AW Gas Dryer
Electric dryer was running fine.had towels in there an opened door to check how wet an noticed it was really hot inside an then closed it an went to pull knob outward to start the dryer again an it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer will only slightly dry my clothers
make sure you have the required 240 volts to the unit,then check the high-limit and cycling thermostat(s) on the element case and make sure you have good air flow through out the unit,if its plugged with lint air won't flow and it won't dry right
Apr 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I have a maytag atlantis dryer and it will not start. I checked the front safety switch and it is working. Light that says damp comes on but does not start
The 304473 thermal fuse has blown. It is located down on the left side of your heater. For a quick check of this you can with the dryer unplugged jump the two wires together making sure they don't touch any metal and plug back in and try to start. 5.00 part.
Jan 28, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer wont start
Push on the door switch and make sure the light goes out. When the light goes out, a contact should be made to allow the motor to run. If you can get to the timer, spray a good electronic contact cleaner inside while rotating the dial. While you have the unit open, vacuum out all the lint, and check for loose wires, especially to the door switch.
Apr 14, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer mde7400ayw won't run
I believe this last one has it right. the timer may be bad or worse, the board could be bad.
Jan 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Only heats on timed drying
Our Kenmore dryer had the same sort of problem (different catchy names.
Problem was that in "smart" modes (by what ever name, the timer motor runs in series with a "dampness" sensor (thermostat, actually, I think) and A RESISTOR.
Resistor burns out--this is the symptom set.
Apr 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Motor is bad= not worth fixing! Sorry, Buy a kenmore or whirlpool- they are good dryers!!!
Dec 12, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
87 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
