Question about Epson Stylus CX6600 All-In-One InkJet Printer
Changing waste pads
Thanks to MrDave who helped me get my 6600 back running again! You also suggested now to change the waste pads. Where do I get new ones and how do I do this change?
Thanks!
  • 4 Answers
Changing waste ink pads is a messy job, and printer dependent not an easy one. You'll have to strip the printer to the point where you can remove the waste ink pads (usually right at the bottom of the printer). At this point you may as well also cleaning out the head cleaning pump. You can either purchase new waste ink pads, wash out old ones or cut up sanitary pads...
Posted on Dec 19, 2013
  • Epson Master
  • 691 Answers
Try this rescue kit that includes everything you need to do the job, including how to clean the old pads instead of buying new ones.
http://www.tradebit.com/filedetail.php/2379162-Documents-eBooks-Technical
Posted on Jan 20, 2008
Why does my Yellow ink print with a deep green tint on my Epson R220?
The symptoms point to some kind of contamination between the cyan and yellow. Most likely is that the yellow nozzles are picking up a small amount of cyan in the cleaning/resting pad when the printer is waiting to print... it's also possible the printhead has started failing and is allowing ink to mix somewhere before the nozzles...
The former is more likely however, especially if you are able to print a few pages of yellow where the greenish tint/lines fade out to become pure yellow.. but then re-appear after the printhead has rested.
Causes of this problem tend to be a backed up waste ink tube or failed pump.. Again it's more likely the former, especially if you've been resetting the waste ink counter and ignoring pad replacement or redirection of the waste ink.
Simplest solution is to locate the waste ink tube (accessible via the access hatch in the back of the printer) and then flush the tube through using a syringe of warm water (don't use excess pressure). Then fit an external waste tank so that the pad ink doesn't back up again (and solve the waste ink issue at the same time).
Obviously if the printhead or waste pump are failing then you have no other options beyond a new printhead, reconditioned model or new printer.
Hope that helps...
Martin
Dec 01, 2012 | Epson Stylus Photo R220 InkJet Printer
Part inside your printer are at the end of their service life.
This message usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back with a new comment to that effect, and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please request further information by posting a new comment.
Apr 05, 2009 | Epson Stylus C46 InkJet Printer
Epson C62 pop up says some parts have reached end of their life
This usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Mar 29, 2009 | Epson Stylus Photo R1800 InkJet Printer
How to change waste pads on Epson R2400?
The R2400 is quite an expensive printer and changing the pads would likely knock the printhead out of gross alignment so if you really must change the pads then I'd recommend getting it done at a service center (much as it pains me to suggest it).
The only time it's really essential to get the pads changed though is if you do a lot of borderless printing as this dumps ink straight to the pads and bypasses the popular external waste ink tank modification.
My recommendation would be to consider getting the printer serviced this once and then immediately install an external waste ink system to your printer and use the SSC or A10-IPR utility from Epson to reset the waste ink counter from there on in.
All the info you need is available via this link
Hope that helps, even if it is a little late..
Mar 19, 2009 | Epson Stylus Photo R2400 InkJet Printer
Waste ink absorber is full
it is problem there many waste ink fall a pad it was most derty then printer call a service
you are a technician you clean it and change new one pad it is like a foam and reset it
Nov 26, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Epson C43SX communication error
It is presumed the 6 posts in this problem are all from the same person. If one (or more) isn't, and my response below doesn't help, would you you start a new separate post on your particular problem.
A solitary blinking red light means that the ink level in one of your cartridges is low, but printing can continue normally until the ink runs out, at which point the red light becomes permanently on. You must now change the ink cartridge before the print will work again.
If the green light is flashing at the same time as the red one, this means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44,60,62 service manuals, as far as ink pad replacement goes, they are the same.
The reference manual is at
http://support2.epson.net/manuals/english/ij/stylusc43/REF_G/INDEX.HTM
which provides good information on the meanings of the error lights.
Please report back with further information if the above advice doesn't help.
Jul 05, 2008 | Epson Stylus C43SX InkJet Printer
Epson stylus photo 820
Hi Ikarp9090
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (820), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
Apr 29, 2008 | Epson Stylus Photo 820 InkJet Printer
Nokia 6600 keypad problem
Dear sir,
pls change the original UI ,if it is not solved than change the key pad IC (both), it will solve the key pad problem.
Jan 18, 2008 | Nokia 6600
Mal function of keys 369# vertical right side keys..
This is realy very bad but only remedy to change the belt and joystick assembly. It is not virus or any other thing. This is hardware problem that u r facing frequently. Do vote if it sounds u satisfactory.
Jan 06, 2008 | Nokia 6600
Error message
OK guys quite a simple one....
with the printer on press & hold both the small red button ( far right ) and the green, colour copy button. Whilst still holding press the power button wait till the unit powers off. Press the power button again, shortly after the unit powers on, the lights flash, let go of the two buttons your holding. The screen shoul dnow say "Init EEPROM" if it doesn't repeat procedure till it does. Now press the green colour copy button once, screen should now say "Push power sw" Press and hold the power button, the unit will power off and on again, now release the power button and your printer should be working again. Now you should change your waste pads......
Dec 05, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
204 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
