WONT GET TO THE BIOS POST AND TURNS ON DIRECT FROM THE MAINS??? ITS TRYING TO POST BUT IM GETTING NOTHING ON THE SCREEN
  • 6 more comments
  • spikebt Nov 14, 2009
    HI, ITS A GIGABYTE GA 81915GA MOTHERBOARD, SOON AS THE MACHINE IS CONNECT TO THE POWER IT TRYS TO START BOOTING (IE FAN GOING AND THE FIRST CLICKS OF STARTING, LIGHTS FLASHING ON DRIVES ETC, BUT IT NEVER STARTS THE GRAPHIC CARD, THEN IT FLASHES AND JUST KEEPS GOING OVER AND OVER, IVE CLEARED THE BIOS AND DISCONNETED EVERY THING FROM THE MOTHERBOARD AND RECONNECTED IT PART AT A TIME NOTHING, IT STARTED WHEN A USB CAMERA LEAD WAS UNPLUGGED FROM THE MACHINE??? I THINK MOTHERBOARD HAS SHORTED?? AND MOST OF THE TIME IT WILL ONLY CLOSE DOWN BY REMOVING THE POWER, ANY IDEAS PLAESE
  • spikebt Nov 16, 2009
    2009 - HI, ITS A GIGABYTE GA 81915GA MOTHERBOARD, SOON AS THE MACHINE IS CONNECT TO THE POWER IT TRYS TO START BOOTING (IE FAN GOING AND THE FIRST CLICKS OF STARTING, LIGHTS FLASHING ON DRIVES ETC, BUT IT NEVER STARTS THE GRAPHIC CARD, THEN IT FLASHES AND JUST KEEPS GOING OVER AND OVER, IVE CLEARED THE BIOS AND DISCONNETED EVERY THING FROM THE MOTHERBOARD AND RECONNECTED IT PART AT A TIME NOTHING, IT STARTED WHEN A USB CAMERA LEAD WAS UNPLUGGED FROM THE MACHINE??? I THINK MOTHERBOARD HAS SHORTED?? AND MOST OF THE TIME IT WILL ONLY CLOSE DOWN BY REMOVING THE POWER, ANY IDEAS PLAESE
    TRIED REMOVING THE BATTERY OVER NIGHT STILL THE SAME
    HI, TRIED THIS IM GETTING NO POST , ITS NOT EVEN GETTING TO THE PIONT WHERE THE GRAPHICS CARD BOOTS IN, ALL THE FANS ARE KICKIN , BUT OTHER THAN THAT ITS JUST AS IF THERES NO MOTHERBOARD CONNECTED , IVE STRIPPED IT BARE AND REBIULT IT AND TRIED REBOOTING WITH EACH COMPAINT CONNECT NOTHING, I THINK THE BOARD HAS POPPED??? OR BIOS CHIP IS FRIED????
  • KENTRONICS
    KENTRONICS May 11, 2010
    what main board is it
  • aayush2009
    aayush2009 May 11, 2010
    Ok, Did you trying removing the Memory (RAM) and start the motherboard? Do you hear the memory error beeps?
  • aayush2009
    What Is your Motherboard Specifications. Please clarify, The Motherboard Model no. and Make.
  • 728 Answers
Hi spikebt,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Posted on Nov 17, 2009
Testimonial: "GOOD SOUND ADVISE"
  • 113 Answers
Remove the cmos battery for about 10 mins,also un-plug the ac cord and re-try.
let me know
ken
Posted on Nov 16, 2009
  • KENTRONICS
    KENTRONICS Nov 16, 2009
    ok do you have another pc that you can attach the hdd to, if not press and hold the f8 key while powering on and try to boot into safe mode when you see like the post is displayed.
    keep me informed
My 50" insignia wont turn on wen im plug to light turn on the screen and red light but turn of with clik nose
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 08, 2016 | Insignia Televison & Video
Starts to the Fujitsu Screen then nothing
No Actually its fixable
There are a number of issues that can cause this but all of them are hardware related.. Mostly its eighter the hard drive or them main board (bios)
1.) Open up the laptop
You do this by removing the hinge covers, then removing the
face panel(part with the power button)
remove the kwyboard and you wiull have axcess to it..
2.) there is a battery on the main board, simply disconnect it, then remove your laptop battery and hit the power button(switch now) seven times.. Hopefully this will discharge any remaing power and reset your bios..
now try booting, if that works, simply enter your bios(setup) and load the optamised defaults then save and exit..
If that fails, Open back up the laptop again and try disconnecting the hard drive.. If it boots and says no boot disc, then your hard drive is defective and needs to be replaced..
If all that fails you will need to replace your mainboard.. if you are not qualified enough to do this i suggest you take it to a technician,,, Let me know what happens and if you need additional information, just post your question here and i shall reply asap
Jan 17, 2008 | Fujitsu LifeBook N3520 Notebook
Black screen
can you see any POST messages when you first turn it on?
ie amount of ram / discs etc..if not try connecting an external
monitor it might be the screen malfunctioning
also is your psu generating the correct voltage ( 18-20v)
if you can , remove ( for 20secs then replace) the internal 5v battery to reset the bios..remove the battery pack and power first though
bottom line is..your mobo could be f****ed or your bios corrupt
best of luck
Jan 14, 2013 | Fujitsu Siemens LifeBook A Series Laptop...
Acer aspire 5551-2036 wont come on..
I read your description carefully, there is no dought in my mind that the motherboard is the issue,acer is well known for problems in that area and unfortuneately there is nothing more you can do, generally I find they get to hot, cooling fans fail, and numerous other situations.
Mar 23, 2012 | Computers & Internet
Diskette drive 0 seeks failure;password
Open the case and reset the BIOS using the jumper: move it from 1-2 pins to 2-3 for 5 minutes.
Jan 02, 2010 | Dell Dimension 2400 PC Desktop
When i press the power button my acer aspire one.it wont boot
I recommend you try the steps in the below link:
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Follow the steps from No Boot or no Power in laptops.
Also check if there is a known issue with your laptop model since even others are experiencing similar issue.
Jun 25, 2009 | Acer Aspire One PC Notebook
Acer One zg5 - updates now wont boot up
Right after the BIOS or POST keep pressing F8 do you get the option to go into safe mode?
Feb 06, 2009 | Acer Aspire 5630 Notebook
Dell D600 wont go into bios mode
Hi ,
if you wanted to get the bios setup you have to press Fn+F1 then you will go to the bios setup
Mar 07, 2008 | Dell Latitude D600 Notebook
Wont even load onto bios.
you could be right but it's hard defining beeps but i would reseat your memory and graphics card as 1 long and 3 short beeps refers mainly to graphics
Aug 28, 2007 | ASUS A8N-SLI Premium Motherboard
Help
dont waste your time is not the video card, Idont know what you put together but if you change the motherboard you have to give some info to it, and thas a technical job look for a tech....good luck
Aug 04, 2006 | Albatron PX865PE Pro Motherboard
Computers & Internet Logo
250 people viewed this question
David Payne
David Payne
