Re: I have a keyboard on my laptop screen and want toget...
Click start and click on run. Type msconfig. Select startup tab, and somewhere it should say the name of the company of the keyboard, and uncheck it. Close the msconfig, it will ask you to reboot and when it does reboot, That should keep it from booting up automatically.
The screen is probably permanently damaged... Some of the juice got into the screen which is bad news. You have to be very careful with liquids around laptop screens, even when your just cleaning it. You should never spray or spill anything on a laptop screen. So if it bothers you too much you'll probably want to bring it to an expert to be replaced.
As for the keyboard you can clean it easily with a damp/wet cloth while it's turned off and the battery removed...
what computer do it have every keyboard has an fn button and an icon showing the webcam you need to find them and press them togeter to put the webcam on
You screen is cracked. It will require replacement.
If it's not the screen, then it's the LCD lamp, which is generally just inside/beside the joint of the screen (where it meets the laptop body). You can try tapping the area gently, to see whether it falls back into place, but if you've got permanent colour defects, it's probably a broken LCD.
Looks like your keyboard have some problems with Dust.
Jammed keys are more caused by getting dusts and other small particles into the keys.
1. Best way of get rid of jammed keys is clean the surface. you can use a small vacuum cleaner for this.
2. Another way is not permanent solution, yet it will give quick results. turn the keyboard back side up. give one or two light slaps on the back of Keyboard. shocks caused by the slaps will move jammed keys. but this is a temporary solution.
The smell comes from your front rubber boot you must replace it toget rid of the smell.The water collects in the inner part of the boot and and sits there till it smells hope i helped
