Question about Vivitar 285HV Flash
Will a Vivitar 285HV fry my Canon EOS 40D? I'd like to experiment with a Vivitar 285HV as an on-camera hot shoe flash. However, I'm reluctant to proceed because of conflicting reports about voltage compatibility with DSLRs. Some say the "HV" designated models are DSLR-safe; others disagree. I'd appreciate getting a definitive answer from someone who's actually tried using the 285HV as an on-camera hot shoe flash with the 40D.
  • 667 Answers
Personally, I would not try it. While the Canon has a protection system built into the camera, the trigger voltage on the Vivitar is pretty high. I have had good results using a 283 on a slave shoe, you will have to stop down more with the extra light
Posted on Jan 08, 2008
    Problem Solver:
  • 8 Answers
The 285HV is indeed the new incarnation of the 285 with a perfectly-safe-for-everyone 6V trigger voltage. No safe-sync required, just plug and go. Actually, I put a meter across the sync terminals on mine, and measured only 4.5V open-circuit, which leads to its own problem: some cheap optical slaves will fail to fire. So watch out for that.
Posted on Jan 28, 2008
  • 216 Answers
Yes, no problem if you check the trigger voltage on the 285HV.
Posted on Jan 14, 2008
  • Alexander Lee Jan 14, 2008
    How can I be rated 80% with 29 votes in less than 1/2 second?
    All Canon EX flashes suck, except the 580EX II.
    They can not be used in the Auto sensor modes because they have no sensor.
    Took Canon over 20 years to put the Auto Sensor and PC connector.
Is Vivitar 1900 electronic flash compatible with canon eos 550d
You have to measure the trigger voltage on the pins of the flash with a voltmeter to make sure it is at 8 volts. If it is higher, you will fry the Nikon. Use the center pin and the one at the edge of the shoe to measure the voltage.
Aug 08, 2012 | Vivitar 1900 electronic flash Flash
Vivitar 3200 flash with Canon EOS Rebel T3
it will work with your rebel t3 just set the flash on manual mode and adjust the desired flash power needed .
Jan 16, 2012 | Canon Rebel Cameras
The main PCB is apparently faulty on my 40D , is there a cheap fix for this , or does it have to be done at a Canon recomended repairer? The quote I have recieved is very expensive
PCB???? Printed Circuit Board? Why do you feel the circuit board is at fault?
Did you set an "old" film flash in the hot shoe like a Vivitar 283? if so you fried the board's flash system.
Or does the pop up internal flash unit not pop up?
Did you attempt to install a large capacity SD card?
Did you fail to format a new card?
Are you getting an error code like "Error 99"?
Unless you fed power into the camera from an incorrect outside power source cable to 110 volt wall socket OR used an old film flash which generates up to 300 trigger volts, I would have some doubts of the Circuit Board being "faulty"
May 03, 2011 | Canon EOS 40D Digital Camera
I have a Vivitar 285HV flash and I'm wondering if the firing voltage is low enough to use with a Canon Rebel Xs digital camera?
According to Vivitar, the 285HV has a trigger voltage of 12V, which should be safe for use with modern digital cameras.
Mar 22, 2011 | Vivitar Cameras
Can I use it wirelessly with a canon EOS 40D
Yes you can but it won't TTL and you will need to fire it from or with a slave/light cell. This will make your system more like a studio set up. You will need to increase/decrease the light intensity using different modifiers for special effects. My portable/location set up uses 2 Vivitar 283's, a Canon 533G, Nikon SB 15 and a Canon 420 EX all fired from little flash slaves. here is an e-Bay reference link
Hope this was a help
May 19, 2010 | Canon Speedlite 540EZ TTL Flash
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
Can I use my Vivitar 385 with my Pentax K200?
Yes, you can use the flash if your camera has a PC connector.
Or, check the trigger voltage: under 7VDC = OK on hotshoe.
Oct 31, 2008 | Vivitar 285HV Flash
Vivitar 3200 Flashgun and Canon EOS 400D
Using Vivitar 3200A flash gun on a DSLR is risky for the following reason. The trigger voltage of a DSLR at flash hot shoe that takes it to its TTL (through the lens) circuit is less than 10 volts, it is about 6 to 8 volts in the recent DSLRs. The trigger voltage generated by Vivitar 3200A at full charge flashing is around 180 volts (max). That is a fatal dose for a sensitive DSLR TTL circuit. This high voltage flash gun will work endlessly, the only damage is to the TTL flash circuit. When you attach a TTL flash to the DSLR after using Vivitar 3200A for sometime, your TTL flash will not communicate with your camera. It will be just another ordinary flash without any auto functions. There is a Wein adapter that you can fix b/w your cameral hot shoe and the vivitar flash gun that is said to reduce the trigger voltage that passes into the camera. Try it if you get it. Without this gadget it is better not to use non recommended and non TTL flashes on latest DSLRs.
Apr 13, 2008 | Cameras
Vivitar 285HV Flash Logo
878 people viewed this question
Top Vivitar Cameras Experts
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
