Question about Acer 7720G-602G50MN C2D 2.2/2/500/17/VHewlett Packard PC Desktop
Power producer cannot find dvd writer Help!! - Acer 7720G-602G50MN C2D 2.2/2/500/17/VHewlett Packard PC Desktop
    Scholar:
  • 57 Answers
1st Check to see if you have power (hit the eject button on the DVD writer). If not then you have a physical problem with the drive. If external DVD then reseat the power connections from the wall and to the drive (also reseat the USB cable from both ends). If internal drive then you would have to make sure the power is plugged in well (i doubt this problem as it almost never happens on an internal drive). If you still have no power for an eject, then you will have to get a replacement drive.
If it does eject, then check the Device Manager (right click "My Computer", select properties, Select the Hardware Tab, Click the "Device Manager" button) to see if your drive shows up. There should be a plus sign or minus sign (+)(-) in front of "DVD/CD-ROM drives". Click the plus sign if you have one, otherwise you should see your DVD writer here. If there is a "red X" on the drive, right-click it and then select "enable". Then your DVD should be active.
Otherwise if you have power and it is already in the device manager, then it is a problem with your Power Producer program and you will need to reinstall it or use another program (which you can find here http://www.thefreecountry.com/utilities/dvdcdburning.shtml) Hope this helps, Best Regards, -md
Posted on Nov 14, 2009
Cannot create dvd
your dvd rw is not read ...change it and try another dvd Rw
Jul 26, 2012 | Photodex ProShow Producer
What is a CD key?
A CD key is typically what software producers use to copy protect their software from piracy. It's a string of letters and numbers that have to be entered correctly before whatever software you are attempting to use can be installed.
May 28, 2012 | HP Computers & Internet
I gotta plextor 712a dvd drive; it does read other media except dvd. blink rate is 2 while color is amber. what should i do as a fix?
Does it read _any_ DVD drive, especially commercially-produced ones?
If not, then it's time to spend $40 to purchase a replacement CD/DVD reader/writer.
Jan 19, 2011 | Plextor PX-712A (PX-712A BLACK) Burner
I bought my SAMSUNG DVD supper writer one year ago . I use Win 7 . It was good up to now . Now , My DVD writer cannot read DVD or CD . I checked plug of DVD writer , my PC told that DVD writer is still...
I would say you need a new CD/DVD. This one appears to have given up. These days, they are not very expensive. var fctb_tool=null; function FCTB_Init_3ebe2b55d0d94800b072c8db741693f5(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_0ef9312c3bb74669a836f0f462a4530a(t) { fctb_tool=t; start(fctb_tool); }
Jan 07, 2011 | Computers & Internet
Program won't let me load and burn onto a dvd disk. Only pull up menu is for saving on hard drive. How do I get to the dvd disk burn drive?
Once you've clicked on "Produce" and then on "Burn to disc" a window appears containing amongst others the choice to burn to hard drive OR to your writer drive. If the words "hard drive" appears in this window, you need to click on the little square on the righthand side of it to bring up the other choice, which will be the name of your writer drive. Choose this and continue. Your slideshow will now be burned to the DVD in the writer drive.
If the pull-up menu only gives you the choice to save to hard drive, there is something wrong with the software. You can get into contact with the technical support team for this software at individualsoftware.com. You have to register your product to get help, but it is all free.
11407336
May 09, 2010 | Individual SlideShow Expressions
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
Jan 22, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
My dvd writer DRU-190A takes 50-60 minutes for each dvd writing.
Just right click on my computer, go to properties> hardware> device manager> IDE ATA/ATAPI Controllers. there u will find several primary and secondary IDE Channels. Right click on first IDE channel and goto properties> Advanced settings, change transfer mode to "DMA if Available". Repeat it with all the channels. If problem still persists then uninstall the channel containing ur DVD Writer and restart your computer. It will detect new hardware as DVD Writer. Now if it is showing the transfer mode "DMA if Available" by default then your problem is solved.
Dec 27, 2008 | Sony 20x Dvd Rw +And -Dru-190a Burner
Installing
Hi tatieyanah...
For installing your DVD Writer follow these steps...
First , Place your DVD Writer in a Suitable position and fix it by the screws.
1. From your CPU SMPS(i.e, power box) you will have many set of wires coming with white plugs.Take one of those wires. Plug that into your writer's back side.REMEMBER you should plug it in the way that Yellow color wire should in the outer end and two black wires in the middle and red at the inner end.
2. If you dont find any wire in your CPU , use the one which is given to you ,which is a splitter in the DVD box.
3. Use the data cable given along with the DVD writer. Connect that Data cable( cable which is Wide and looks like stripes) from ur Mother board to the back side of the DVD writer. Take care that it is not connected upside down.
IF U NEED MORE INFO, REFER "http://www.computer-adviser.com/how-to-install-dvd-writer.html".
Post me your replies.....Bye ...take care...
Sep 17, 2008 | Computers & Internet
COMPUTER
No ,there is no software that can help you to burn dvd when you have cd writer ......you have to purchase a dvd writer in order to burn dvd files
May 17, 2008 | Computers & Internet
Acer 7720G-602G50MN C2D 2.2/2/500/17/VHewlett Packard  PC Desktop Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
