Question about Brother MFC-8440 All-In-One Laser Printer
Machine has a catching noise
Sounds like my gears are not running smooth making an errrrrg noise
of course i stopped the machine so i am not sure if it is even printing.
  • 233 Answers
See if it's printing or not, usually the fuser gears wear out and either the gears need replacing or the full fuser assembly, there are other possibilities but this is likely the cause
NOTE: try removing the cartridge then turn on to make sure it's not that
thanks for rating
Posted on Jan 10, 2008
6ya staff
SOURCE:
Maytag top load washing machine 2 years old
This could be partly the clutch/break assy. You need to be able to run this with the lid open in the spin position. Activte the lid switch with a pencil or something. Reach in and hold the spin basket and then turn the washer on in spin. Hold this basket for 1-2 minutes then release it and let it reach full speed then stop the washer by turning the timer off or releasing the lid switch. See if the hard breaking/noise is better. Keep doing this untill it comes to a smooth stop and the noise is gone at the stop. Not sure this will cure the noise in the spin starting up problem or not, but start here. the clutch gets rust on the pads and this burnishes the break pads, removing this rust that makes it grab.
Goodluck..
Apr 05, 2008 | Washing Machines
Why the transmissiom won' engage in any gear
Transmission won't engage Drive or Reverse - EricTheCarGuy
www.ericthecarguy.com/.../53999-transmission-won-t-engage-drive-or-r...
This transmission shifted smooth and strong through all gears until today when it stopped all of ... Any idea on where we should start tackling this issue? .... Also, make sure that the pressure tester is not leaking or you will run the tranny dry(use ...
Gear shifter goes from park to drive with no effect. Won't ...
Nov 26, 2015 | Cars & Trucks
How we can solved the hp lj p2055dn printer noise
Hopefully one of the first four suggestions helped you. If not if you could post more detail as to what kind of noise is the machine making: a grinding noise, a squealing noise, how loud is it. descriptions such as that would be helpful in diagnosing the issue. Without a description of the noise any of those first four posts could be relevant. The easiest thing to try first would of course be a toner cartridge I have experienced them many times making noises especially if they're aftermarket cartridges. Other than that grinding noises are typically fuser related in that machine, with squealing and high pitch noises the description of the noise is very important because it could be a fuse or it could just be dirt in a gear cluster rubbing on a shaft or it could be the laser assembly. Ireally hate to post absolute diagnosis without enough detail especially when it comes to you having to spend more money. Hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
Sep 24, 2014 | HP P2035N LaserJet Monochrome Printer
2010 ford focus automatic trsnsmission makes rubbing noise when accelerating from acomplete stop . noise continues until 2nd gear engages. from then on all is fine. reverse sometimes doesnt engage, ma
A carrier bearing usually pertains to the differential assembly and would not cause the symptom you describe. There is a problem with this transmission that causes it to not drop completely to first gear after a period of driving. Ford is aware of it but I do not believe they have initiated a recall. Call your Ford dealer(s) to see if you can find an honest man. Ask for the service manager.
Mar 25, 2014 | 2010 Ford Focus 1.6
Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Dec 13, 2013 | Precor C956i Treadmills with HR /...
When I turn wash machine on it runs for maybe a min then starts cuttin out sounds like something loosing power it just stops spin an makes stauling noise can someone help
Do not do it anymore! It is shorting out and could catch on fire. You need to replace the connector! Look for parts on the Kenmore site
Nov 25, 2012 | Washing Machines
Kitchenaid Professional HP mixer, motor stopped while making dough. I let everything cool down and with no attachments it will not turn on. As soon as you turn it on the motor gets hot but no noise or...
Open the Transmission Housing and remove the two screws holding
the Motor. Lift it off the gears and test run it by itself. The motor
should run normally at different speeds. If it does, then you can move on
to the gears. Manually turn the Worm Gear and make sure nothing got jammed.
The Bevel Gear should turn smoothly.
Jul 18, 2011 | KitchenAid KP2671 Professional 6 Series...
Brother MFC-8440 All-In-One Laser Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
