Question about Hitachi 27UX01B 27" TV
Hitachi tv model no c2574tny2-311
Part of the model number as come up in the middle of the screen
c74tn311 can you help
0 characters
1 Points
Hitachi tv repair manual
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Reasons for this fault has been described in detail. Search the site with this keyword 'horizontal line fault'.
May 05, 2014 | Standard (CRT) Televisions
Hitachi model CMT-2928 Serian Number GIK 000287 after turn on the television around 5 second screen become flicker like have thunder.please help for this issue to solve thank
do you smell something at the back of your tv. if yes and still hearing the continues cricking sound its your flyback transformer it has a leak a high voltage current is arching try to replace the flyback transformer.
Oct 15, 2010 | Hitachi CMT-2195 21" TV
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
Does there exist a manual for Hitachi Natura Tv, progressive scan on net?
Please intimate exact model number of your Hitachi TV to look for user manual. Model number would be written on sticker pasted at back of TV.
Jun 15, 2009 | Hitachi Standard (CRT) Televisions
Cant get a picture
check the vertical section dry solder or vertical ic supply or is vertical ic is short. please let me know the ic number for clear idea
Jun 24, 2008 | Hitachi 35UX85B 35" TV
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Black display with a horizontal white line in the middle.
Middle going across the screen from left to right??
This unit is plagued with bad solder connections in the comb filter board and flatpack underneath the comb filter board. These connections can cause any odd number of problems in video display. If it is that it's not expensive - virtually no parts. If it's a single line across the screen could also be the vertical circuit involved.
My suggestion is to have it estimated at a reputable shop and take it to them rather than the more expensive pu/del charges.
If you would like go to and locate a servicer from there. Kinda like going to the AMA to find a doctor...
Hope this helps!
Apr 18, 2008 | Hitachi 32UDX10S 32" TV
need model and chassis number and I' may help you email me
Mar 20, 2008 | Hitachi C21RF39 21" TV
NO Sound on Hitachi 42" big screen
what is your model number please ?
Jan 27, 2008 | Hitachi 43FDX01B TV
Hitachi 27UX01B 27" TV Logo
60 people viewed this question
Top Hitachi Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Standard (CRT) Television Expert? Answer questions, earn points and help others
