Question about Dishwashers
Whirlpool Dishwasher stops during cycle, clean light flashing
Whirlpool Dishwasher DU1055XTPQ0.
Purchased this dishwasher 3 years ago and have been having problems from the beginning. The problem is that it stops during mid cycle and the clean button flashes 7 times. I am aware this is a very common problem. When it was still under warranty, we had a service call on it, and fixed the problem by setting our hot water heater over 130 degrees. The 2nd time this occurred and it wasn’t under warranty, the service company was nice enough to let us know the fix – Push the High Temp Button then Heated Dry button - hit back and forth 3 times and the washer will reset itself. This usually will reset the machine for about 3 months and then it happens again. It has happened again and I have tried to reset it 3 times but now it does not fix it.
2 months ago, we also had a problem were had it shut down during a cycle but that time we did not have any lights or power to the unit, and had to replace the fuse, which did fix that problem. (I am one of the lucky ones that has a husband that is very handy)
Since these are such a common problems, doesn’t Whirlpool have a fix? Or is my fix simply to replace the unit? Do you think I will ever buy another Whirlpool appliance again?
4 Suggested Answers
  • 188 Answers
SOURCE: clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
SOURCE: "Heater Circuit Malfunction" Kenmore 16033
I have a QuietGuard 3. The sequence Hi Temp, Heated Dry two times initiated a "lock on" so I tried reversing it to Heated Dry then Hi Temp (twice) and now my machine is operating normally. Thanks so much for this helpful, money saving information!
Posted on Nov 23, 2010
  • 3247 Answers
SOURCE: The washing, heated dry, and
please provide the make and model number of the dishwasher.
do you hear pumps running? what was the last cycle it was at when the flashing started. was there water left at the base of the dishwasher from the cycle that stopped?
Posted on Dec 16, 2010
My Whirlpool GU2400XTP83 stopped during the wash cycle and there is a blinking light above the "light" cycle button. I can not reset the dishwasher, stop or start it.
To reset the dishwasher push in this order the,
the control will be reset...but more importantly how many times ina row does the light will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
Sep 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
My Whirlpool DU1145XTP won't turn on. Clean light
Check the themistor in the control panel. Radio Shack sells these for about $1.30 each. I replaced the one in my dishwasher three years ago and have had no issues since.
May 16, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Fault light flashing,
Is it please possible for you to add additional comments in your query about dishwasher problem
1. make and model number of dishwasher
2. are there any fault codes or lights showing up - which ones
3. at what cycle does the operation stop - eg still washing and there is water in dishwasher - is it warm/ cold, rinse is starting (can hear the pump) but stops halfway, rinse is complete but does not dry..
4. how old is the unit
clarification on above will help understand the problem better.
Jan 03, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool GU2300 Dishwasher. The machine stops for long periods during the cycle. All lights go out. If the machine is opened before the cycle finishes, it will not resume. If I try to restart, the normal...
Door latch.
Open and close the door to make sure the door latch is securely fastened.
Check the dishwasher wiring for a possible loose connection where it connects to the house wiring.
Fuses or circuit breakers.
Check your house fuses or circuit breakers to make sure you have power to the dishwasher.
Thanks for contacting
Oct 24, 2009 | Dishwashers
Just installed a whirlpool dishwasher du1055xtpq0. when trying to start it the start light just flashes
Sounds like the door isn't latching properly,sometimes this can be from not being level,the tub can torque to one side and the latch doesn't line up correctly.
Aug 22, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Clean light flashes
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
Is the right cycle selected? Refer to the “Cycle Selection
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Jul 02, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
Dishwashers Logo
188 people viewed this question
Top Dishwashers Experts
