Question about Canon PIXMA MP240 All-In-One InkJet Printer
How I can reset my canon mp270,lamp B is lighting all the time. I have filled black ink and know my printer dont recognizes cartridge. My computer shows that it is empty.
Posted on Jun 08, 2010
  • dellatoti Oct 24, 2010
    Fake solution!! Try this:
    YOU CAN PRINT WITH THIS PRINTER...all you need to do is press the reset button for 10 seconds ( the one with the upside down triangle) print print something. when it tells you to replace the cartridge press the red triangle button for 10 seconds and it wIll resume printing,,,( beware when you do this you cannot monitor the ink levels you`ll have to keep your on the prints.....DO NOT LET THE CARTRIDGES RUN DRY THIS WILL SHORTEN THERE LIFE IF NOT KILL THEM )
  • 4 Answers
You can do a factory reset on the canon printer so it will recognize your cartridge. I have tried refilling mine and got some errors but it worked after the reset, try the steps from this site. How to reset canon mp270 I hope it will work for you too.
Posted on Aug 16, 2012
I have a canon pixma 270 that you can refill the ink cartridges on...how do you reset the ink monitor because it just says ink empty and will not let me print. new cartridges are to expensive so refilling...
If you do a google search you will find a way of over riding the "protectionism" that the printer companies design their printers with so you have to use their lousy, overpriced ink products.
Sep 03, 2017 | Canon Pixma MP270 All-in-One InkJet...
Canon mp270 error code 5200
Hello and WelcomeError 5200 is a service error. Follow this solution step by step
  1. With the printer turned on,unplug it
  2. Open the top and bring the ink cartridge holder to the middle
  3. Raise the gray bar and remove the print head assembly with the cartridges in it
  4. Lower the gray bar with the head missing and close the top with the head out
  5. Restore the power,wait till the printer starts
  6. It will tell you to put in the cartridges, Put in the cartridge
  7. Restore the print head, close the top and the printer will resume working
Error will be removed.
If you have already tried all of the above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
So go to the Canon Service Center. If you want to get support on Call then
Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
Please rate my solution as Four Thumbs if it was helpful. Thank you for using FixYa
Mar 10, 2011 | Canon Pixma MP270 All-in-One InkJet...
Error occurred 6000
It's an ink level indication.
If you are using re-filled ink cartridges, try this.
To solve the ink level error in canon Pixma iP1800/Canon Pixma iP1880. This problem usually appear after refilled the cartridge on the canon printer and ink level indicator showing the ink cartridge is empty although you have filled a cc Ink into the cartridge. And if the problem occur you cannot using your printer to print. The solution you must reset ink level on the printer if you want your computer work again.
If you have a problem like that you ca follow this tutorial to solve your printer problem, here how:
Turn of the printer and Disconnect the power cable to the printer.
Press power button on the printer. While pressing the button connect the power cable to the power source (the power indicator will light in green)
While still holding power button press resume button twice - orange blink and return to green.
Release the power button, then the PC will recognize new cartridge installed (If the power indicator on the printer steady in green you continue to Steps 5)
Run the IPtools software, please await after this software detect your printer correctly or you can set the printer model on "Change Model" section.
Click "reset black and reset color" button to reset the ink level and Click "reset main and reset platen" to reset waste ink counter. After clicked the button you will see ink level of the cartridge on in the IPTol info has 100% and WP and WM has set to 0. Click Exit on IPTool
Turn off the printer and turn on again.
On the reset procedure above usually the problem found on steps 1-4 to make the printer steady light in green. On my experiment if steps 1-4 does not work on your printer, you can use manual reset method for canon iP1700 before continue to steps 5.
Good luck
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
After installing new black cartridge into printer will not print!
dear friend
this error due to filled waste tank You must replace waste ink tank.Visit u r nearest canon service location or dealer point
Jul 02, 2009 | Canon BJC 7100 InkJet Printer
Refilled ink cartridges not recognizby printer.
I fixed the problem by using original Canon ink cartridges and not getting them refilled. Apparently their chemists put a chemical in all of their inks so that only their Canon printers will recognize. It's a guarded trade secret that no one else knows about, unless it was analized. Other ink manufacturers produce ink that looks exactly as Canon ink, but that's where the similiarities end.
Nov 24, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
Jul 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
CANON 1P4200 PRINTER
I would try a new ink tank. They do go bad even though they have ink in them.
Mar 21, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printer fail to recognize the ink cartridge
You need to wait longer for the printer to recognize the ink cartridge, but first clear all cartridge error messages on the printer.
Jun 25, 2017 | OEM Systems PIXMA iP3300 Photo Printer
Canon PIXMA MP240 All-In-One InkJet Printer Logo
10,165 people viewed this question
old marine
old marine
